SnapCenter 4.7 cmdlets
Remove-SdPortSetPort
Deletes a specified port from your portset.
Syntax
Remove-SdPortSetPort [-PortSetName]  <String>  [-Port]  <String>  [-StorageSystem]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
PortSetName
Specifies the name of the portset from which you want to delete a port.
true
true (ByPropertyName)
Port
Specifies the port you want to delete from your portset.
true
StorageSystem
Specifies the storage system on which your portset resides.
true
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
