SnapCenter 4.7 cmdlets
Remove-SmDRFailoverBackups
After failback, delete special backups taken during failover.
Syntax
Remove-SmDRFailoverBackups [-AppObjectId]  <>  [-AppObjectId]  <>  [-BackupNames]  <>  [-AppObjectId]  <>  [-Primary]  <>
Detailed Description
Name Description Required? Pipeline Input Default Value
AppObjectId
Specifies the application object identifier of an SQL database.
true
true (ByPropertyName)
BackupNames
Specifies one or more backups of an application object to delete.
false
BackupIds
false
Primary
Specifies to delete backups from the primary storage.
false
Example 1: Delete all special backups of the SQL resources after failback from secondary
 Remove-SmDRFailoverBackups -AppObjectId Host1\Inst\DB1
This example syntax deletes all the special backup of the resource from the storage where the backup was taken (secondary storage).
		Are you sure you want to remove the backups?
		[Y] Yes  [A] Yes to All  [N] No  [L] No to All  [S] Suspend  [?] Help (default is "Y"): yes
		Result   : SMCoreContracts.SMResult
		TotalCount   : 0
		DisplayCount : 0
		Context  :
		Job  : SMCoreContracts.SmJob
Example 2: Delete few special backups of the SQL resource after failback
 Remove-SmDRFailoverBackups -AppObjectId Host1\Inst\DB1 -BackupNames Backup1,Backup2
This example syntax deletes the specified special backups from the storage where the backup was taken (secondary storage).
		TotalCount   : 0
		DisplayCount : 0
		Context  :
Example 3: Delete all special backups of the SQL resources after failback from the secondary and the primary.
 Remove-SmDRFailoverBackups -AppObjectId Host1\Inst\DB1 -Primary
This example syntax removes all the resource backups taken during failover from the secondary and the primary storage. For SnapMirror relationship, during subsequent SnapMirror update, deleted backups in the primary storage will be reflected in the secondary storage.
		TotalCount   : 0
		DisplayCount : 0
		Context  :
Example 4: Delete few special backups of the SQL resources after failback from the secondary and the primary.
 Remove-SmDRFailoverBackups -AppObjectId Host1\Inst\DB1 -BackupNames Backup1,Backup2 -Primary
		TotalCount   : 0
		DisplayCount : 0
		Context  :
