SnapCenter 4.7 cmdlets
Remove-SmGroup
Removes an AD group or local group from SnapCenter.
Syntax
Remove-SmGroup [-Group]  <SmString>  [-Domain]  <String>
Detailed Description
Removes an Active Directory group or local group from SnapCenter.
Name Description Required? Pipeline Input Default Value
Group
Single group or list of groups belonging to the same domain or local host.
true
true (ByPropertyName)
Domain
The domain to which the group belongs to. Local group should skip this parameter.
false
Example 1: Removing a single group
 Remove-SmGroup -Group group1 -Domain domain1
Example 2: Removing multiple groups of same domain
 Remove-SmGroup -Group group1,group2  -Domain domain1
Example 3: Removing a local group
 Remove-SmGroup -Group LocalGroup1
