SnapCenter 4.7 cmdlets
Remove-SmGroupFromRole
Removes a group from a specified role.
Syntax
Remove-SmGroupFromRole [-Domain]  <String>  [-Group]  <SmString>  [-RoleName]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Domain
Specifies the domain to which the group belongs.
false
true (ByPropertyName)
Group
Specifies the group you want to remove from the role.
true
RoleName
Specifies the name of the role from which you want to remove a group.
true
Example 1: Removing a group from a role
 Remove-SmGroupFromRole -Domain sddev -Group administrators -RoleName SnapcenterAdmin
This example syntax removes the specified group from the SnapCenterAdmin role.
Are you sure you want to unassign the group from role?.
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y
Successfully UnAssigned Group From Role
Example 2: Removing a group from a role without confirm dialogue
 Remove-SmGroupFromRole -Domain sddev -Group administrators -RoleName SnapcenterAdmin -Confirm:$false
