SnapCenter 4.7 cmdlets
Rename-SdIgroup
Renames your specified igroup.
Syntax
Rename-SdIgroup [-Name]  <String>  [-NewName]  <String>  [-StorageSystem]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Name
Specifies the name of the igroup you want to rename.
true
true (ByPropertyName)
NewName
Specifies the new name of the igroup you are renaming.
true
StorageSystem
Specifies the storage system on which the igroup you want to rename is located.
true
Session
Specifies the session ID from Open-SmConnection.
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Example 1: Renaming an igroup
 PS C:\> Rename-SdIgroup -Name IG_Demo -NewName IG_Demo_Renamed -StorageSystem  172.17.168.13
This examples syntax renames an existing igroup.
