SnapCenter 4.7 cmdlets
Rename-SdSnapshot
Renames Snapshot copies created on a Windows disk or SMB share.
Syntax
Rename-SdSnapshot [-Path]  <Object[]>  [-Snapshot]  <String>  [-NewName]  <String>  [-Session]  <String>  [-Host]  <String>  [-StorageSystem]  <String>  [-VolumeName]  <String>  [-Snapshot]  <String>  [-NewName]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Renames Snapshot backups created on a Windows disk or SMB share.Related cmdlets: New-SdSnapshot and Remove-SdSnapshot
Name Description Required? Pipeline Input Default Value
Path
Specifies a list of SMB shares or Windows volumes. You cannot mix a logical disk or mount point with SMB shares in the same input path.
true
true (ByPropertyName)
Snapshot
Specifies the name of the Snapshot copy you want to rename.
true
NewName
Indicates the new name of the Snapshot copy.
true
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
StorageSystem
Specifies the name of storage system name for the Snapshot copy you are renaming.
true
VolumeName
Specifies the storage system volume name for the Snapshot copy.
true
Example 1: Rename a single Snapshot copy
 PS C:\> Rename-SdSnapshot -Path \\SQLCIFSServer\SalesDBShare -Snapshot MySnap -NewName MyNewSnap
This example renames a Snapshot copy from MySnap to MyNewSnap.
SnapshotName AccessPoint StorageSystemName Volume
MyNewSnap \\SQLCIFSServer\SalesDBShare MyStorageSystem1 vol1
Example 2: Rename a Snapshot copy on two SMB shares
 PS C:\> Rename-SdSnapshot -Path \\SQLCIFSServer1\SalesDBShare,\\SQLCIFSServer2\MarketDBShare -Snapshot MySnap -NewName MyNewSnap
This example renames a Snapshot copy located two SMB shares.
MyNewSnap \\SQLCIFSServer1\SalesDBShare MyStorageSystem1 vol1
MyNewSnap \\SQLCIFSServer2\MarketDBShare MyStorageSystem2 vol2
Example 3: Rename a Snapshot copy on a specified storage system and volume
 PS C:\> Rename-SdSnapshot -StorageSystem MyStorageSystem1 -VolumeName vol1 -Snapshot MySnap -NewName MyNewSnap
This example renames a Snapshot copy from MySnap to MyNewSnap on a specified storage system and volume.
MyNewSnap MyStorageSystem1 vol1
Example 4: Renames a single Snapshot copy on a disk
 PS C:\> Rename-SdSnapshot -Path F: -Snapshot MySnap -NewName MyNewSnap
This example renames a Snapshot copy on the disk drive :F from MySnap to MyNewSnap.
