SnapCenter 4.7 cmdlets
Set-SdSnapMirrorPolicyRule
Sets the rules for managing Snapshot retention on the SnapVault secondary storage system.
Syntax
Set-SdSnapMirrorPolicyRule [-SourceStorageSystem]  <String>  [-SourceStorageSystemVolume]  <String>  [-DestinationStorageSystem]  <String>  [-DestinationStorageSystemVolume]  <String>  [-SnapMirrorLabel]  <String>  [-Retention]  <Int32>  [-Preserve]  <>  [-WarnThreshold]  <Int32>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Sets the rules for managing Snapshot retention on the SnapVault secondary storage system. You can create new rules for customizing your virtual storage server level SnapMirror policy. Each SnapMirror policy can have up to 10 rules managing Snapshot copy retention. The default policy rules are daily or weekly Snapshot copy retention, or you can define your own retention rule. You cannot modify cluster-level SnapMirror or SnapVault policies with virtual storage server credentials.Related cmdlets: Remove-SdSnapMirrorPolicyRule, Get-SdSnapMirrorPolicyRule
Name Description Required? Pipeline Input Default Value
SourceStorageSystem
Specifies the primary storage system name containing the source volumes of the SnapMirror relationship for which you want to create or modify the SnapMirror policy rules. IP addresses are not supported.
true
true (ByValue, ByPropertyName)
Specifies the source volume of the SnapMirror relationship for which you want to create or modify the SnapMirror policy rules.
true
true (ByPropertyName)
Specifies the secondary storage system name containing the destination volumes of the SnapMirror relationship for which you want to create or modify the SnapMirror policy rules. IP addresses are not supported.
true
Specifies the destination volume of the SnapMirror relationship for which you want to create or modify the SnapMirror policy rules.
true
SnapMirrorLabel
Specifies the SnapMirror policy rule which you want to create or modify.
true
Retention
Specifies the Snapshot copy retention count.
true
Preserve
Specifies whether Snapshot copy preserve is enabled, which determines the behavior when the Snapshot copy retention count is reached on the SnapMirror Vault destination.
false
WarnThreshold
Specifies the warning threshold count.
false
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Example 1: Setting SnapMirror policy rule information on the policy for a SnapMirror relationship
 PS C:\> Set-SdSnapMirrorPolicyRule -SourceStorageSystem vs01 -SourceStorageSystemVolume src_vol01 -DestinationStorageSystem vs02 -DestinationStorageSystemVolume dest_vol01 -SnapMirrorLabel myWeekly -Retention 8 -Preserve -WarnThreshold 3 -verbose -Confirm:$false
Create or modify the SnapMirror policy rule "myWeekly" on the policy of the specified relationship.
PS C:\Users\administrator.NEXTGEN> Set-SdSnapMirrorPolicyRule -SourceStorageSystem vserver1 -SourceStorageSystemVolume snapvault_source -DestinationStorageSyst
em vserver1 -DestinationStorageSystemVolume snapvault_dest -SnapMirrorLabel test -Retention 8 -Preserve -WarnThreshold 3 -Verbose
Set SnapMirror policy rule on vserver1 : snapvault_source ==> vserver1 : snapvault_dest.
Do you want to continue?
[Y] Yes  [A] Yes to All  [N] No  [L] No to All  [S] Suspend  [?] Help (default is "Y"):
VERBOSE: Setting SnapMirror policy rules.
The setting SnapMirror policy rules operation is successful.
VERBOSE: Operation successful.
