SnapCenter 4.7 cmdlets
Set-SmCloneDataSet
Modifies an existing clone dataset.
Syntax
Set-SmCloneDataSet [-DataSetName]  <String>  [-Description]  <String>  [-Policies]  <String>  [-PluginCode]  <PluginCode>  [-CloneToInstance]  <String>  [-Resources]  <Hashtable[]>  [-Suffix]  <String>  [-SchedulerCredentialName]  <String>  [-ArchivedLocators]  <Hashtable[]>  [-EnableEmail]  <>  [-EmailPreference]  <SmEmailNotificationPreference>  [-EmailFrom]  <String>  [-EmailTo]  <String>  [-EmailSubject]  <String>  [-EmailBody]  <String>  [-CustomSnapShotFomat]  <String>  [-CustomText]  <String>  [-RemoveCustomSnapShot]  <>
Detailed Description
Name Description Required? Pipeline Input Default Value
DataSetName
Specifies the name of the clone dataset you want to modify.
true
true (ByPropertyName)
Modifies the optional description of the clone dataset.
false
Policies
Modifies which policies are attached to the clone dataset.
false
PluginCode
true
CloneToInstance
Changes the SQL Server instance that you want to clone to. All databases in the clone dataset are cloned to this instance.
true
Resources
Modifies the list of resources you want to add to the clone dataset.You must provide the resource information in a hashtable, and it must contain the resource name and type, and the host on which it is located. For example,@{"Host"="localhost";"Type"="SQL Database";"Names"="Instance\Database"}Valid Type values are: SQL Database, SQL Instance, SQL Availability Group.You can include comma-separated values for Names.
true
Suffix
Modifies a clone name suffix. All clones you create with one clone job are appended with the same suffix name.
false
false
ArchivedLocators
false
EnableEmail
Specifies whether to enable or disable e-mail.
false
false
EmailPreference
Specifies when you will receive e-mail notifications.Possible values: Always, Never, OnError, OnErrorOrWarning.
false
false
EmailFrom
Specifies the sender's e-mail address.
false
EmailTo
Specifies the recipient's e-mail address.
false
EmailSubject
Specifies the subject of the e-mail.
false
EmailBody
Specifies the body of the e-mail.
false
CustomSnapShotFomat
Specifies the custom Snaphsot copy naming format.
false
CustomText
Specifies the custom text in the custom Snapshot copy naming format.
false
Specifies the removal of the custom Snapshot copy naming format associated with the dataset.
false
Example 1: Modifying a clone dataset with a new suffix
 Set-SmCloneDataSet -DataSetName payroll_dataset -Resources @{"Host"="vise-f3.sddev.mycompany.com";"Type"="SQLDatabases";"Names"="vise-f3\SQLExpress\payroll"}  -CloneToInstance vise-f4\sqlexpress  -Suffix __
          newSuffix
This example syntax modifies a clone dataset by adding a new suffix.
Description :
CreationTime: 8/6/2015 2:27:08 PM
ModificationTime: 8/6/2015 2:27:08 PM
EnableEmail :
EmailSMTPServer :
EmailFrom   :
EmailTo :
EmailSubject:
EnableSysLog: False
ProtectionGroupType : Clone
EnableAsupOnFailure : False
Policies: {}
HostResourceMaping  : {}
Configuration   : SMCoreContracts.SmCloneConfiguration
LastBackupStatus:
VerificationServer  :
EmailBody   :
EmailNotificationPreference :
VerificationServerInfo  :
SchedulerSQLInstance:
CustomText  :
CustomSnapshotFormat:
SearchResources : False
ByPassRunAs : False
IsCustomSnapshot:
MaintenanceStatus   : Production
PluginProtectionGroupTypes  :
Type: Group
Id  :
Host:
UserName:
Passphrase  :
Deleted : False
Auth: SMCoreContracts.SmAuth
IsClone : False
CloneLevel  : 0
Example 2: Modifying a clone dataset
 Set-SmCloneDataSet -DataSetName payroll_dataset -Resources @{"Host"="vise-f3.sddev.mycompany.com";"Type"="SQLDatabases";"Names"="vise-f3\SQLExpress\payroll,vise-f3\SQLExpress\edrive"}  -CloneToInstance vise-f3\sqlexpress
Description :
CreationTime: 8/6/2015 3:06:25 PM
ModificationTime: 8/6/2015 3:06:25 PM
EnableEmail :
EmailSMTPServer :
EmailFrom   :
EmailTo :
EmailSubject:
EnableSysLog: False
Policies: {}
LastBackupStatus:
EmailBody   :
CustomText  :
ByPassRunAs : False
IsCustomSnapshot:
Type: Group
Id  :
Host:
UserName:
Passphrase  :
Deleted : False
IsClone : False
CloneLevel  : 0
