SnapCenter cmdlets
Set-SmDomain
Modify a domain registered with SnapCenter Server.
Syntax
Set-SmDomain [-Name]  <String>  [-Protocol]  <String>  [-FQDN]  <String>  [-IPAddresses]  <String>  [-DCHostNames]  <String>  [-Credential]  <PSCredential>
Detailed Description
Name Description Required? Pipeline Input Default Value
Name
NETBIOS name of the registered domain to be modified.
true
true (ByPropertyName)
Protocol
Protocol of the domain to be modified.By default the protocol value is LDAP. You can specify LDAPS to use the secured windows active directory communication.
false
FQDN
FQDN of the domain to be modified.Used for both LDAP and LDAPS protocol, when you provide the correct FQDN while adding or modifying the domain with LDAP protocol, the domain resolves and the IP address that you might have entered using the IPAddresses parameter is not stored.
false
IPAddresses
Domain IP Addresses of the disjoint domain to be modified.When you provide the correct FQDN while adding or modifying the domain, the domain resolves and the IP address is not stored.
false
DCHostNames
Domain host name of the disjoint or the same domain to be modified.For LDAPS protocol, DCHostNames is a mandatory parameter. The IP address should resolve and the user should not be permitted to manually provide the IP address.
false
Credential
Provides local workgorup administrator credentials to execute a Set-SmDomain cmdlet.This is an optional parameter only can exercise if Open-SmConnection is broken due to Active Directory connectivity using LDAPS protocol.
false
Example 1: Modify a domain registered with SnapCenter Server.
 Set-SmDomain -Name ad12 -FQDN ad12.test.netapp.com -IPAddresses 192.168.0.44
Modified the domain ad12.
DomainFQDN : ad12.test.netapp.com
DCHostIPAddresses  : 192.168.0.44
TrustedDomains :
CreatedOn  :
ModifiedOn :
Port   : 389
Protocol   : LDAP
DCHostNames:
Example 2: Modifying a registered domain protocol from LDAP to LDAPS.
 Set-SmDomain -Name ad12 -DCHostNames WS2K12DC.ad12.test.netapp.com -Protocol LDAPS
TrustedDomains :
CreatedOn  :
ModifiedOn :
Port   : 636
Protocol   : LDAPS
DCHostNames: WS2K12DC.ad12.test.netapp.com
Example 3: Modifying a registered domain protocol from LDAPS to LDAP.
DCHostIPAddresses  :
TrustedDomains :
CreatedOn  :
ModifiedOn :
Port   : 389
Protocol   : LDAP
DCHostNames:
Example 4: Execute Set-SmDomain when Open-SmConnection is broken due to Active directory.
 Set-SmDomain -Name ad12 -FQDN ad12.test.netapp.com -Credential administrator
DCHostIPAddresses  :
TrustedDomains :
CreatedOn  :
ModifiedOn :
Port   : 389
Protocol   : LDAP
DCHostNames:
