SnapCenter cmdlets
Set-SmPluginConfiguration
Sets the host plug-in configuration.
Syntax
Set-SmPluginConfiguration [-PluginCode]  <PluginCode>  [-HostName]  <String>  [-HostLogFolders]  <Hashtable[]>  [-FCIInstanceLogFolders]  <Hashtable[]>  [-IgnoreVscConfiguredCheck]  <Boolean>
Detailed Description
Name Description Required? Pipeline Input Default Value
PluginCode
Specifies the plug-in type. Valid types are SCW and SCSQL.
true
true (ByPropertyName)
HostName
Specifies the host name for which you are setting the plug-in configuration.
true
HostLogFolders
Specifies the host log folders.
false
Specifies the FCI instance log folders.
false
false
true (ByValue, ByPropertyName)
Example 1: Setting the plugin configuration for a standalone host
 Set-SmPluginConfiguration -PluginCode SCSQL -HostName localhost -HostLogFolders @{"Host"="vise-f6";"Log Folder"="S:\LOGBACKUP"}
This example syntax sets the plug-in configuration for the specified standalone host.
SnapCenter has detected that your host is running on a VM. If you use an VMDK or RDM environment, you must add a Virtual Storage Console for vSphere type host; however, if your VM uses iSCSI direct attached disks, you can proceed with the existing host setup.
Choose Yes, if you are using a VM in a VMDK or RDM environment
Choose No, if you are using a VM with iSCI direct attached disks only
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"):
Example 2: Setting the plugin configuration for a cluster host
          -HostName V67VMCLUS -HostLogFolders @{"Host"="v6vmw2012r2";"Log Folder"="S:\LogBackup"},@{"Host"="v7vmw2012r2";"Log Folder"="S:\LogBackup"} -FCIInstanceLogFolders @{"FCI Instance"="vise-f6\FCIInstance";"Log Folder"="R:\"}
This example syntax sets the plug-in configuration for the specified cluster.
