SnapCenter cmdlets
Set-SmRepositoryConfig
Enables you to rebuild the slave repository from the master repository and enables you to fail over the repository to the specified node.
Syntax
Set-SmRepositoryConfig [-ServerToRebuild]  <String>  [-Force]  <>  [-RebuildSlave]  <>  [-Force]  <>  [-ActiveMaster]  <String>  [-Force]  <>  [-Credential]  <PSCredential>  [-SMSbaseUrl]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
ServerToRebuild
Specifies the slave node for which you want to rebuild its repository from the master repository.
true
true (ByPropertyName)
Force
Specifies that you want to force failover even when the slave repository data is not in sync with the master repository data.NOTE: Forcing failover might result in data loss.
false
RebuildSlave
Specifies that SnapCenter automatically identifies the slave node for which to rebuild the repository from the master repository.
true
ActiveMaster
Specifies the slave node that should become the master node.
true
Credential
Enables you to provide domain user credentials required to perform failover operations.
false
SMSbaseUrl
Specifies the SnapCenter Server base URL. The base URL includes the name or IP address of the SnapCenter Server, and, if the remote system is in a different domain than the SnapCenter Server, the domain name. For example: https://SNAPCENTER_SERVER_NAME/DOMAIN_NAME.
false
Example 1: Failover SnapCenter repository to the specified database server
 Set-SmRepositoryConfig -ActiveMaster 10.236.221.0 -Credential mva\administrator
This example syntax fails over the SnapCenter repository to the specified database server.
Are you sure want to failover SnapCenter repository to '10.236.221.0'?
[Y] Yes  [A] Yes to All  [N] No  [L] No to All  [S] Suspend  [?] Help (default is "Y"): Y
Name: SnapCenter Repository Failover to host '10.236.221.0'
StartTime   : 4/28/2017 8:20:35 AM
EndTime : 4/28/2017 8:20:35 AM
IsCancellable   : False
IsRestartable   : False
IsCompleted : False
IsVisible   : True
IsScheduled : False
PercentageCompleted : 100
Description :
Status  : Completed
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 35
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  :
Example 2: Rebuilding a specified slave repository
 Set-SmRepositoryConfig -ServerToRebuild 10.236.221.34
This example syntax rebuilds the specified slave repository.
Are you sure want to rebuild SnapCenter repository on host '10.236.221.34'?
Name: SnapCenter Repository Rebuild on host '10.236.221.34' for High Availability
StartTime   : 4/28/2017 8:15:12 AM
EndTime :
IsCompleted : False
IsVisible   : True
IsScheduled : False
PercentageCompleted : 0
Description :
Status  : Queued
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 35
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  :
Example 3: Rebuilding the current slave repository
 Set-SmRepositoryConfig -RebuildSlave
This example syntax rebuilds the current slave repository.
Are you sure want to rebuild SnapCenter passive repository?
StartTime   : 4/28/2017 8:12:25 AM
EndTime :
IsCompleted : False
IsVisible   : True
IsScheduled : False
Description :
Status  : Queued
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 35
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  :
Example 4: Failing over the SnapCenter repository to the specified database server from a remote host to SnapCenter using a base URL
 Set-SmRepositoryConfig -ActiveMaster 10.236.221.34 -Credential mva\administrator -SMSbaseUrl https://10.236.221.75:8146/
This example syntax fails over the SnapCenter repository to the specified database server from a remote host to SnapCenter using a base URL.
Are you sure want to failover SnapCenter repository to '10.236.221.34'?
Name: SnapCenter Repository Failover to host '10.236.221.34'
StartTime   : 4/28/2017 8:17:47 AM
EndTime : 4/28/2017 8:17:47 AM
IsCompleted : False
IsVisible   : True
IsScheduled : False
Description :
Status  : Completed
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 35
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  :
Example 5: Forcing SnapCenter repository failover with possibility of data loss
 Set-SmRepositoryConfig -ActiveMaster 10.236.221.34 -Credential mva\administrator -SMSbaseUrl https://10.236.221.75:8146/ -Force
This example syntax forces a SnapCenter repository failover even though data loss might occur.
There could be a possible data loss after SnapCenter repository failover to '10.236.221.34'
Do you still want to continue?
StartTime   : 4/28/2017 8:24:48 AM
EndTime : 4/28/2017 8:24:48 AM
IsCompleted : False
IsVisible   : True
IsScheduled : False
Description :
Status  : Completed
Owner   :
Error   :
Priority: None
Tasks   : {}
ParentJobID : 0
EventId : 0
JobTypeId   : 35
ApisJobKey  :
ObjectId: 0
PluginCode  : NONE
PluginName  :
