SnapCenter 4.7 cmdlets
Update-SmBackup
Updates the raw device mapping (RDM) information of a backup.
Syntax
Update-SmBackup [-BackupId]  <Int64>  [-BackupName]  <String>  [-AccessPath]  <String>  [-DataStoreName]  <String>  [-RdmFileName]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
BackupId
Specifies the ID of the backup to update.
false
false
BackupName
Specifies the name of the backup to update.
false
false
AccessPath
Specifies the RDM file system's drive letter or mount point.
true
false
DataStoreName
Specifies the datastore of the RDM file at the time of the backup.
true
false
RdmFileName
Specifies the RDM file path at the time of the backup.
true
false
Example 1: Update RDM information to backup
 Update-SmBackup -BackupId 20 -AccessPath R:\ -DataStoreName "csmdev-SMSQL-ds02"
          -RdmFileName "[csmdev-SMSQL-ds02] csmdev-SMSQL-vm02\csmdev-SMSQL-vm02_1.vmdk"
Result   : SMCoreContracts.SMResult
TotalCount   : 0
DisplayCount : 0
Context  :
Job  : SMCoreContracts.SmJob
