SnapCenter 4.8 cmdlets
Add-SmCloneDataSet
Creates a new clone dataset.
Syntax
Add-SmCloneDataSet [-DataSetName]  <String>  [-Description]  <String>  [-PluginCode]  <PluginCode>  [-Policies]  <String>  [-CloneToInstance]  <String>  [-Resources]  <Hashtable[]>  [-Suffix]  <String>  [-SchedulerCredentialName]  <String>  [-ArchivedLocators]  <Hashtable[]>  [-EnableEmail]  <>  [-EmailPreference]  <SmEmailNotificationPreference>  [-CreateRemoteClone]  <Boolean>  [-CustomSnapShotFomat]  <String>  [-CustomText]  <String>
Detailed Description
Creates a new clone resource group and adds resources to it. Additionally, you can attach policies, set notification settings for Event Management System (EMS) logs, AutoSupport, and email notification. You can also specify clone options including clone server and instance, mount options, and attach a suffix to the clone database name. If you are cloning to a SnapMirror or SnapVault destination, specify the secondary location.
Name Description Required? Pipeline Input Default Value
DataSetName
Specifies the new clone dataset name.
true
true (ByPropertyName)
Provides an optional description of the resource group you are creating.
false
PluginCode
Specifies the plug-in code of the host for which you are creating a clone resource group. Valid values are SCSQL and SCO.
true
Policies
Specifies one or more polices you want to attach to the dataset. Multiple policies can be added as a comma-separated list.
false
CloneToInstance
Specifies the SQL Server instance that you want to clone to. All databases in the clone resource group are cloned to this instance.
true
Resources
Specifies the resources you want to add to the clone resource group.You must provide the resource information in a hashtable, and it must contain the resource name and type, as well as the host on which the resource is located. For example,@{"Host"="localhost";"Type"="SQL Database";"Names"="Instance\Database"}Valid Type values are SQL Database and Oracle Database.You can include comma-separated values for Names.
true
Suffix
Provides a clone name suffix. All clones you create with one clone job are appended with the same suffix name.
false
false
ArchivedLocators
Specifies in a hashtable the secondary storage system details for each unique primary storage system resource in the resource group. For example:-ArchivedLocators @{Primary="my_vs1:my_vol_iscsi";Secondary="my_vs1:my_vol_iscsi_SECONDARY"}
false
EnableEmail
Specifies whether email notification is enabled. The value is either True or False.
false
false
False
EmailPreference
Specifies when you will receive email notifications.Possible values: Always, Never, OnError, OnErrorOrWarning.
false
false
CreateRemoteClone
Specifies whether or not you are creating a remote clone. The value is either True or False.
false
false
CustomSnapShotFomat
Specifies the custom Snapshot copy naming format. For example, -CustomSnapShotFomat '$CustomText$ResourceGroup$Policy$HostName' -CustomText NetApp
false
CustomText
Specifies the custom text in the custom Snapshot copy naming format.
false
EmailBody
Specifies the body of the email.
false
EmailFrom
Specifies the sender's email address.
true
EmailTo
Specifies the recipient's email address.
true
EmailSubject
Specifies the subject of the email.
true
EnableEmailAttachment
Specifies that you are adding an email attachment.
false
Example 1: Creating a new clone dataset from the primary and adding resources
 Add-SmCloneDataSet -DataSetName payrollclone_dataset -Description "Dataset for payroll database" -Policies clonefromprimary_ondemand -Resources @{"Host"="vise-f3.sddev.mycompany.com";"Type"="SQLDatabases";"Names"="vise-f3\SQLExpress\payroll,vise-f3\SQLExpress\finance"} -Suffix __clone -CloneToInstance vise-f3\sqlexpress -AutoAssignMountPoint
This example syntax creates a new clone dataset from the primary and adds resources.
Description : Dataset for payroll database
CreationTime: 8/5/2015 2:18:38 PM
ModificationTime: 8/5/2015 2:18:38 PM
EnableEmail :
EmailSMTPServer :
EmailFrom   :
EmailTo :
EmailSubject:
EnableSysLog:
ProtectionGroupType : Backup
EnableAsupOnFailure :
Policies: {}
HostResourceMaping  : {}
Configuration   : SMCoreContracts.SmConfiguration
LastBackupStatus:
VerificationServer  :
EmailBody   :
EmailNotificationPreference :
VerificationServerInfo  : SMCoreContracts.SmVerificationServerInfo
SchedulerSQLInstance:
CustomText  :
CustomSnapshotFormat:
SearchResources : False
ByPassRunAs : False
IsCustomSnapshot:
MaintenanceStatus   : Production
PluginProtectionGroupTypes  : {SMSQL}
Type: Group
Host:
UserName:
Passphrase  :
Deleted : False
Auth: SMCoreContracts.SmAuth
IsClone : False
CloneLevel  : 0
Example 2: Creating a new clone from a secondary clone
 Add-SmCloneDataSet -DataSetName clone_mdml_ds_mirror -Policies SMcln_full_logbkp_winsched -CloneToInstance "mva-m13-u25
          " -Resources @{"Host"="mva-m13-u25";"Type"="SQL Database";"Names"="mva-m13-u25\TEST"} -ArchivedLocators @{Primary="rajr_vs1:rajr_vol_iscsi";Secondary=
          "rajr_vs1:rajr_vol_iscsi_SECONDARY"} -Suffix "_RAJR"
This example syntax creates a new clone from a secondary clone using the -ArchivedLocators parameter.
Description :
CreationTime: 5/20/2015 11:10:04 AM
ModificationTime: 5/20/2015 11:10:04 AM
EnableEmail : False
EmailSMTPServer :
EmailFrom   :
EmailTo :
EmailSubject:
EnableSysLog: False
ProtectionGroupType : Clone
EnableAsupOnFailure : False
Policies: {SMcln_full_logbkp_winsched}
Configuration   : SMCoreContracts.SmCloneConfiguration
LastBackupStatus:
EmailBody   :
EmailNotificationPreference : Always
CustomText  :
ByPassRunAs : False
IsCustomSnapshot: False
Type: Group
Id  :
Host:
UserName:
Passphrase  :
Deleted : False
IsClone : False
CloneLevel  : 0
