SnapCenter 4.8 cmdlets
Add-SmResource
Creates a custom plug-in resource or an Oracle plug-in application volume resource to be protected.
Syntax
Add-SmResource [-HostName]  <String>  [-PluginCode]  <PluginCode>  [-CredentialName]  <String>
Detailed Description
Creates resource of a given ResourceType, where the resource types supported for a custom plug-in are specified as part of the plug-in description file or you can create an Oracle plug-in application volume resource.You can also use the cmdlet to associate storage of type Volume or Qtree or LUN with given resource. If required, you can also specify custom parameters specific to the resource along with a Run As account, which can be used by the plug-in to validate credentials to access the resource.
Name Description Required? Pipeline Input Default Value
HostName
The name of the SnapCenter Custom Plug-in or Oracle Plug-in host.
true
true (ByPropertyName)
PluginCode
The name of the plug-in associated with the resource you are adding. Possible inputs include SCSQL, SCW, SCO, HANA and SCU.
true
CredentialName
false
ResourceType
The type of application object. This parameter does not accept any special characters or spaces. For example, instance, database, or a SAP HANA SingleContainer or MultipleContainers.
true
ResourceName
The name of the application object.
true
StorageFootPrint
Specifies the storage footprint. You enter the storage footprint using the following format:-StorageFootPrint @(@{"VolumeName"="Volume";"StorageSystem"="server"}, @{"LunPath"="/vol/Volume/LunPath";"StorageSystem"="server"}, @{"QtreeName"="qtree";"VolumeName"="volume";"StorageSystem"="server"})
true
MountPoints
Specifies the mount point for the resource.
false
ResourceSettings
Specifies the custom resource parameters. You enter ResourceSettings in a hastable using key-value pairs. For example:-ResourceSettings @{"Key1" = "Value1"; "Key2" = "Value2"}
false
DatabaseName
SAP HANA Database name.
true
SID
This is a SAP HANA database specific parameter. A SAP HANA system is identified by aunique 3 letter system ID (SID). For example, ABC.
true
UserStoreKeys
Comma separated list of SAP HANA database UserStoreKeys.
true
FileBackupPath
Location of the SAP HANA node on which the SAP HANA File-Based Backup is saved. This is required when EnableFileBackup parameter is set to ‘Y’. The path must start with a forward slash and it cannot contain * ? \ " < > | characters.If the path is not provided, SAP HANA will use the default path configured on the system. For example, /hana/shared/{SID}/HDB {INSTANCE_ID}/backup/data.
false
FileBackupPrefix
Prefix added to the File-Based Backup name. This is required when EnableFileBackup parameter is set to ‘Y’. Use only letters, numbers, and underscores for the prefix of File-Based Backup name.If prefix is not provided, default value will be used.
false
OSDBUser
true
TenantDatabaseName
This is a SAP HANA database specific parameter. It is the name of the tenant database for SAP HANA MultiTenant Database Containers resource type.
false
TenantType
This is a SAP HANA database specific parameter. This specifies the tenant type of SAP HANA MultiTenant Database Containers. SingleTenant as tenant type is deprecated.SingleTenant as tenant type is deprecated
true
MultiTenant
Example 1: Adding a resource with a single storage volume
 Add-SmResource -HostName 'host.example.com' -PluginCode 'DB2' -ResourceName DB1-ResourceType Database -StorageFootPrint (@{"VolumeName"="autoVol1";"StorageSystem"="vserver_scauto_primary"}) -Instance db2inst3
This example syntax adds a Resource Type Database of Custom plug-in DB2. In this example, the resource parent type is Instance, which is mandatory as indicated by the plug-in descriptor file used during Upload-SmPluginPackage.
PluginName : DB2
Uid: db2inst3\DB1
ParentUid  :
SmAppFiles :
SmAppFileStorageGroups : {}
PluginParams   : SMCoreContracts.SmKeyValueCollection
MountPaths :
LastBackupDate :
LastBackupStatus   :
IsProtected: False
Type   : Database
Host   : sccrheldb2.sccore.test.com
UserName   :
Passphrase :
Deleted: False
Auth   : SMCoreContracts.SmAuth
IsClone: False
CloneLevel : 0
Hosts  :
Example 2: Adding a resource with ResourceType instance containing multiple Storage Type LUNs
 Add-SmResource -HostName 'host.example.com' -PluginCode 'DB2' -ResourceName db2inst1 -ResourceType Instance -StorageFootPrint (@( @{"VolumeName"="DB2_NONRECDB";"LunName"="DB2_NONRECDB";"StorageSystem"="vserver_scauto_primary"}, @{"VolumeName"="DB2_NONREC1DB";"LunName"="DB2_NONREC1DB";"StorageSystem"="vserver_scauto_secondary"}, @{"VolumeName"="DB2_RECDB";"LunName"="DB2_RECDB";"StorageSystem"="vserver_scauto_primary"}))
This example syntax adds a resource with ResourceType for custom Plug-in DB2. ResourceType instance does not have parent Resource type.
The resource named db2inst1 is spread across 3 LUNs of different volumes of same storage system.
PluginName : DB2
Uid: db2inst1
ParentUid  :
SmAppFiles :
SmAppFileStorageGroups : {, , }
MountPaths :
LastBackupDate :
LastBackupStatus   :
IsProtected: False
Type   : Instance
UserName   :
Passphrase :
Deleted: False
IsClone: False
CloneLevel : 0
Hosts  :
Example 3: Adding a resource with storage type qtree
 Add-SmResource -HostName 'sccorelinux188.sccore.test.com' -PluginCode 'DB2' -ResourceName DominoAutoDatabase -ResourceType Database -StorageFootPrint  (@{"QTREENAME "="inventory_qtree";"VolumeName"="inventory_vol";"StorageSystem"="vserver_scauto_primary"}) -Instance INST
This example syntax adds a resource type of Database for custom plug-in DB2, hosting data on qtree.
Cmdlet Output: Successfully added the following resource
PluginName : DummyPlugin
Uid: INST\DominoAutoDatabase
ParentUid  :
SmAppFiles :
MountPaths :
LastBackupDate :
LastBackupStatus   :
IsProtected: False
Type   : Database
utoDatabase
Host   : sccorelinux188.sccore.test.com
UserName   :
Passphrase :
Deleted: False
IsClone: False
CloneLevel : 0
Hosts  :
Example 4: Adding a resource that includes a LUN inside a qtree
 Add-SmResource -HostName "10.236.164.10" -PluginCode hana -ResourceType instance -ResourceName mixedres -StorageFootPrint @(@{"storagesystem"="10.232.206.5";"volumename"="dummyvol"},@{"storagesystem"="10.232.206.5";"volumename"="dummyvol2";"lunname"="luninsidevol"},@{"storagesystem"="10.232.206.5";"volumename"="dummyvol3";"lunname"="qtreeforlun\luninsideqtree"},@{"storagesystem"="10.232.206.5";"volumename"="dummyvol4";"qtreename"="qtreeinsidevol"})
This example adds a resource with custom plug-in resource type that includes a LUN inside a qtree.
PluginName : hana
Uid: A12
ParentUid  :
SmAppFiles :
MountPaths :
LastBackupDate :
LastBackupStatus   :
IsProtected: False
Type   : Instance
UserName   :
Passphrase :
Deleted: False
IsClone: False
CloneLevel : 0
Hosts  :
Example 5: Adding a SAP HANA database of SingleContainer type
 Add-SmResource -HostName 'mva-s63.gdl.englab.netapp.com' -PluginCode 'hana' -SID 'H14' -DatabaseName 'Manual_H14' -ResourceType SingleContainer -StorageFootPrint (@{"VolumeName"="R808267D015V1_NFS_H14_SC_DATA_10_229_37_43";"StorageSystem"="10.232.206.133"}) -UserStoreKeys 'KEY01' -OSDBUser 'SYSTEM'
This example syntax adds the SingleContainer resource type with specific SID and database name.
PluginName : hana
Uid: H14
ParentUid  :
SmAppFiles :
MountPaths :
pluginConfiguration: SMCoreContracts.SmSCSAPHANAResourceParameters
AutoDiscovered : False
IsSelectable   : True
IsAuthenticated: False
IsProtected: False
ReplicationEnabled : False
LastBackupDate :
LastBackupStatus   :
IsWindowsResource  : False
Type   : SingleContainer
Host   : mva-s63.gdl.englab.netapp.com
UserName   :
Passphrase :
Deleted: False
IsClone: False
CloneLevel : 0
Hosts  :
StorageName:
ResourceGroupNames :
PolicyNames:
Key: 0
NsmObjectID: 0
SizeOfSmObject :
Example 6: Adding a SAP HANA Multitenant Database Container resource type
 Add-SmResource -HostName 'schana02.gdl.englab.netapp.com' -PluginCode 'hana' -DatabaseName MDC -ResourceType MultipleContainers -StorageFootPrint ( @{"VolumeName"="hana_data2";"StorageSystem"="storage_admin_1"}) -sid 'MT1' -tenanttype 'MultiTenant' -userstorekeys 'USKMT1' -tenantdatabasename 'MT1' -osdbuser 'root'
This example adds a HANA MultiTenant Database Container resource with MultiTenant tenant type. Tenant database names will be detected during backup operations.
WARNING: TenantDatabaseName parameter is now deprecated for MultiTenant database resource, the parameter will be ignored and auto discovered internally.
PluginName : hana
Uid: MDC\MT1
ParentUid  :
SmAppFiles :
MountPaths :
IsSelectable   : True
LastBackupDate :
LastBackupStatus   :
IsProtected: False
Type   : MultipleContainers
Host   : schana02.gdl.englab.netapp.com
UserName   :
Passphrase :
Deleted: False
IsClone: False
CloneLevel : 0
Hosts  :
StorageName:
PolicyNames:
Key: 0
NsmObjectID: 0
SizeOfSmObject :
Example 7: Adding an Oracle Application Volume Resource with a volume,lun and qtree
 Add-SmResource -HostName 'R8092776CF4V1.HNK2.com' -PluginCode 'SCO' -ResourceName appVol -StorageFootPrint @(@{"VolumeName"="vol_test1";"StorageSystem"="10.232.206.165"},@{"VolumeName"="vol_test2";"LunName"="lun_test1";"StorageSystem"="10.232.206.165"},@{"QtreeName"="qtree_test1";"VolumeName"="vol_test3";"StorageSystem"="10.232.206.165"})
This example adds an Oracle Application Volume Resource which contains a volume, lun, and qtree.
Uid: appVol
			IsProtected: False
			LastBackupDate :
			LastBackupStatus   :
			Type   : Application Volume
			Host   : R8092776CF4V1.HNK2.com
			UserName   :
			Passphrase :
			Deleted: False
			IsClone: False
			CloneLevel : 0
			Hosts  :
			StorageName:
			PolicyNames:
			Key: 0
			NsmObjectID: 0
			SizeOfSmObject :
Example 8: Adding an Oracle Application Volume Resource with a single lun
 Add-SmResource -HostName 'R8092776CF4V1.HNK2.com' -PluginCode 'SCO' -ResourceName appVolLun -StorageFootPrint @{"VolumeName"="vol_test2";"LunName"="lun_test1";"StorageSystem"="10.232.206.165"}
This example adds an Oracle Application Volume Resource which contains a single lun
Uid: appVolLun
			IsProtected: False
			LastBackupDate :
			LastBackupStatus   :
			UserName   :
			Passphrase :
			Deleted: False
			IsClone: False
			CloneLevel : 0
			Hosts  :
			StorageName:
			PolicyNames:
			Key: 0
			NsmObjectID: 0
			SizeOfSmObject :
