SnapCenter cmdlets
Add-SmStorageConnection
Creates a new storage system connection.
Syntax
Add-SmStorageConnection [-Storage]  <String>  [-Port]  <UInt16>  [-Protocol]  <ConnectProtocol>  [-Timeout]  <Int32>  [-Credential]  <PSCredential>  [-PreferredIP]  <String>  [-DisableAsupOnFailure]  <>  [-DisableSysLog]  <>  [-Type]  <StorageSystemType>  [-PlatformType]  <String>  [-NetAppAccountName]  <String>  [-CredentialName]  <String>  [-CredentialId]  <bigint(20)>  [-ResourceGroup]  <String>  [-IsSecondary]  <>
Detailed Description
Creates a new storage system connection. You must create your storage system connection in advance of performing any provisioning or data protection jobs.
Name Description Required? Pipeline Input Default Value
Storage
true
true (ByPropertyName)
Port
Specifies the port for the storage system connection. 80 is the default port for HTTP and 443 is the default port for HTTPS.
false
Protocol
Specifies the communication protocol you want to use to connect to the storage system. Valid values are: HTTP and HTTPS.
true
Timeout
Specifies the storage system connection timeout in seconds. The default timeout is 60 seconds. However, in a scaled environment,increasing the timeout to 300 seconds is recommended.
false
60
Credential
Specifies the storage system credentials. You must have created valid storage system credentials in advance.
true
PreferredIP
Specifies the preferred IP address for the storage system management or data LIF IP address.
false
Disables Auto Support in case of any failure.
false
DisableSysLog
Disables system log.
false
Type
Specifies the type of storage being added. Valid value are DataOntap and AzureNetAppAccount.
false
NetAppAccountName
Specifies the Azure NetApp Account Name.
false
CredentialName
Specifies Azure NetApp Credential name.
false
CredentialId
Specifies Azure NetApp Credential ID.
false
ResourceGroup
Specifies resource group.
false
PlatformType
This optional parameter specifies the SVM platform type for licensing purposes. Possible values are Hardware and Software. Hardware indicates that you are using a FAS or All Flash FAS plaform. Software indicates that you are using ONTAP Cloud or ONTAP Select.If you specify Type as ONTAP SVM as the storage connection type,and you do not specify PlatformType, the default value is set to Hardware.
false
IsSecondary
false
Example 1: Creating a new storage system connection
 Add-SmStorageConnection -SVM neeraj_vs1 -Protocol Https -Timeout 60
This example syntax creates a new storage system connection.
cmdlet Add-SmStorageConnection at command pipeline position 1
Supply values for the following parameters:
(Type !? for Help.)
Credential
UserName:
Password:
Port: 443
TransportType   : Https
ModifyTime  : 1/1/0001 12:00:00 AM
Mode:
OntapiMajorVersion  :
OntapiMinorVersion  :
Version : NetApp Release 8.2.1RC2X9 Cluster-Mode: Mon Jan 13 09:30:32 PST 2014
StorageSystemOSType : DataOntap
Passphrase  :
Timeout : 60
Uuid:
OperationContext:
PreferredIpAddress  :
Aliases : {neeraj_vs1-mc, neeraj_vs1}
SmIPAddresses   : {SMCoreContracts.SmIPAddress, SMCoreContracts.SmIPAddress, SMCoreContracts.SmIPAddress,
SMCoreContracts.SmIPAddress...}
IPAddresses : {172.17.124.165, 172.17.124.165, 172.17.124.165, 172.17.124.165...}
IsResolved  : True
IsValid : True
Identity: test_vs1
Example 2: Creating a new Azure NetApp Account using credential name
 Add-SmStorageConnection -Type AzureNetAppAccount -NetAppAccountName "azureNetappAccount1" -CredentialName "AzureCred1" -ResourceGroup "azure_rg1"
This example syntax creates a new Azure NetApp Account using credential name.
Example 3: Creating a new Azure NetApp Account using credential ID
 Add-SmStorageConnection -Type AzureNetAppAccount -NetAppAccountName "azureNetappAccount1" -CredentialId 1 -ResourceGroup "azure_rg1"
This example syntax creates a new Azure NetApp Account using credential ID.
