SnapCenter cmdlets
Configure-SmOracleDatabase
Configures Oracle Database in SnapCenter. This includes configuring database authentication with port, ASM authentication with port and Oracle Recovery Manager (RMAN) catalog database. For Oracle RAC database, preferred nodes for backup operation can be configured.
Syntax
Configure-SmOracleDatabase [-AppObjectId]  <String>  [-DatabaseCredentialName]  <String>  [-AsmCredentialName]  <String>  [-OracleRmanCatalogTnsName]  <String>  [-OracleRmanCatalogCredentialName]  <String>  [-ASMPort]  <Int32>  [-DatabasePort]  <Int32>  [-OracleRACPreferredNodes]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
AppObjectId
Specifies the application object identifier of an Oracle Database that needs to be configured. You need to specify the application object identifier format as 'host\database' for Oracle standalone database or 'clustername\database' for Oracle RAC database.
true
true (ByPropertyName)
false
AsmCredentialName
false
Specifies the TNS name of Oracle Recovery Manager (RMAN) catalog database.
false
false
ASMPort
Specifies the port where the Oracle ASM listener is running.Default: 1521
false
1521
DatabasePort
Specifies the port where the Oracle Database listener is running.Default: 1521
false
1521
Specifies one or more Oracle RAC database preferred nodes you want to configure for backup operation. Oracle RAC Nodes must be specified in a comma separated values in the order of their preference.
false
Example 1: Configure database credentials for Oracle Database.
 Configure-SmOracleDatabase -AppObjectId host-name\STDDB -DatabaseRunAsName stddb_cred -DatabasePort 1521
This example shows how to configure database credentials for Oracle Database.
Example 2: Configure RAC preferred node settings for Oracle Database.
 Configure-SmOracleDatabase -AppObjectId oracle-rac-cluster\RACDB -OracleRACPreferredNodes rac-node1.netapp.com,rac-node3.netapp.com,rac-node2.netapp.com
This example shows how to configure RAC preferred node settings for Oracle Database.
