SnapCenter 4.8 cmdlets
Get-SdIscsiInitiator
Enumerates information about iSCSI sessions and initiators.
Syntax
Get-SdIscsiInitiator [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Session
Specifies the session ID from Open-SmConnection.
false
true (ByPropertyName)
Host
Specifies the name of the computer or host on which the SnapDrive service you want to perform the operation runs. The default is your local machine.
false
Example 1: Listing all iSCSI sessions and initiators
 PS C:\> Get-SdIscsiInitiator
In this example syntax, you list all iSCSI sessions and associated initiators.
