Get-SmAssignedUsers
Gets the users assigned to a specified role.
Syntax
Get-SmAssignedUsers [-RoleName] <String>
Detailed Description
Name | Description | Required? | Pipeline Input | Default Value |
RoleName |
Specifies the role name. |
true |
true (ByPropertyName) |
Example 1: Gets users associated with a role
Get-SmAssignedUsers -RoleName SnapCenterAdmin
This example syntax gets the users associated with a role.
Token : TokenHashed : {} TokenTime : 8/3/2015 5:30:59 PM FullName: sddev\administrator Author : Domain : sddev Description : TokenNeverExpires : False IsAdmin : False TenantAdmin : IsNewUser : UserGroupObjectType : User RoleName: RoleId : 0 Name: administrator Type: Id : 1 Host: UserName: Passphrase : Deleted : False Auth: SMCoreContracts.SmAuth IsClone : False CloneLevel : 0 Token : TokenHashed : {} TokenTime : 8/3/2015 5:30:59 PM FullName: sddev\snapdrive Author : Domain : sddev Description : TokenNeverExpires : False IsAdmin : False TenantAdmin : IsNewUser : UserGroupObjectType : User RoleName: RoleId : 0 Name: snapdrive Type: Id : 2 Host: UserName: Passphrase : Deleted : False Auth: SMCoreContracts.SmAuth IsClone : False CloneLevel : 0
