SnapCenter 4.8 cmdlets
Get-SmLogSettings
Retrieves log settings.
Syntax
Get-SmLogSettings [-Server]  <>  [-Agent]  <>  [-HostName]  <String>  [-Plugin]  <>  [-HostName]  <String>  [-PluginCode]  <PluginCode>
Detailed Description
Retrieves the log settings for SnapCenter, a host, or a plug-in. Log setting determine the log severity level, the maximum file size for the log file, the maximum number of log file backups to retain, and the maximum size for all job log files.
Name Description Required? Pipeline Input Default Value
Server
Retrieves log file settings for SnapCenter Server.
true
false
Agent
Specifies that you want to retrieve log file settings for SnapCenter host agent.
true
false
HostName
Provides the host name for the SnapCenter host that will capture the log files.
true
false
Plugin
Specifies that you want to retrieve log file settings for a plug-in.
true
false
PluginCode
Provides the plug-in code for the plug-in for which you want to retrieve the log file settings. Valid plug-in codes are SCSQL, SCV, and SCO. For custom plug-ins, the plug-in code is the name of the custom plug-in.
true
false
Example 1: Getting log file settings for SnapCenter Server
 Get-SmLogSettings -Server
This example syntax retreives log file settings for SnapCenter Server.
LogSettingsId  : 1
LogSettingsType: Server
LogLevel   : All
MaxFileSize: 10485760
MaxSizeRollBackups : 10
JobLogsMaxFileSize : 104857600
HostId :
HostName   :
PluginInfoId   :
PluginCode :
Example 2: Getting log file settings for SnapCenter host agent
 Get-SmLogSettings –Agent –HostName host123
This example syntax retrieves log files for the SnapCenter host agent.
LogSettingsId  : 1
LogSettingsType: Agent
LogLevel   : All
HostId : 1
HostName   : bryankDev
PluginInfoId   :
PluginCode :
Example 3: Getting log file settings for plugins
 Get-SmLogSettings –Plugin –PluginCode SCSQL –HostName bryankDev
This example syntax retrieves plug-in log file settings.
LogSettingsId  : 1
LogSettingsType: Plugin
LogLevel   : Info
HostId : 1
PluginInfoId   : 1
PluginCode : SMSQL
