SnapCenter 4.8 cmdlets
Remove-SdLun
Removes a LUN from your storage system.
Syntax
Remove-SdLun [-StorageSystem]  <String>  [-LunPath]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
StorageSystem
Specifies the storage system on which your LUN is located.
true
true (ByPropertyName)
LunPath
Specifies the path of the LUN on your storage system. If you are working in an ONTAP environment, specify the path to your LUN. If you are working in a Flashray, specify the LUN name.
true
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
