SnapCenter 4.8 cmdlets
Remove-SdPortSet
Deletes a portset.
Syntax
Remove-SdPortSet [-PortSetName]  <String>  [-ForceDestroy]  <>  [-StorageSystem]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Deletes a portset.
Name Description Required? Pipeline Input Default Value
PortSetName
Specifies the name of the portset you want to delete.
true
true (ByPropertyName)
ForceDestroy
Specifies that you want to forcibly delete a portset.
false
StorageSystem
Specifies the name of the storage system on which the portset you want delete resides.
true
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
