SnapCenter cmdlets
Remove-SdSnapshot
Removes Snapshot copies created on Windows disks, SMB shares, or storage system volumes.
Syntax
Remove-SdSnapshot [-Path]  <Object[]>  [-Snapshot]  <String[]>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Removes Snapshot copies created on Windows disks, SMB shares, or storage system volumes.Related cmdlets: New-SdSnapshot, Rename-SdSnapshot, and Restore-SdSnapshot
Name Description Required? Pipeline Input Default Value
Path
Specifies the SMB shares, volume, or logical disk for the Snapshot copies you want to delete. You cannot mix a logical disk or mount point with SMB shares in the same input path.
true
true (ByPropertyName)
Snapshot
Specifies the list of Snapshot copies you want to delete.
true
Session
Specifies the session ID from Open-SmConnection.
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Example 1: Removing a Snapshot copy on a SMB share
 PS C:\> Remove-SdSnapshot -Path "\\172.17.12.101\share" -Snapshot "snapshot_1"
This example syntax removes the Snapshot copy snapshot_1 created on SMB share \\172.17.12.101\share.
Example 2: Removing specified Snapshot copies on multiple SMB shares
 PS C:\> Remove-SdSnapshot -Path "\\172.17.12.101\share1","\\172.17.12.101\share2" -Snapshot "snapshot_1","snapshot_2"
This example removes Snapshot copies snapshot_1 and snapshot_2 created on SMB shares \\172.17.12.101\share1 and \\172.17.12.101\share2.
Example 3: Removing a new Snapshot copy on a SMB share
 PS C:\> New-SdSnapshot -Path "\\172.17.12.101\share" | Remove-SdSnapshot
This example removes the new Snapshot copy on SMB share \\172.17.12.101\share.
Example 4: Removing a Snapshot copy on a disk
 PS C:\> Remove-SdSnapshot -Path D: -Snapshot "snapshot_1"
This example syntax removes the Snapshot copy snapshot_1 created on the disk drive D:.
