SnapCenter cmdlets
Remove-SdStorageConnectionSetting
Removes the storage connection, transport, and credential settings from the configuration repository for one or more storage system or virtual storage server.
Syntax
Remove-SdStorageConnectionSetting [-StorageSystem]  <String[]>  [-HostOnly]  <>  [-PassThru]  <>  [-LegacyContext]  <>  [-Session]  <String>  [-Host]  <String>  [-All]  <>  [-HostOnly]  <>  [-PassThru]  <>  [-LegacyContext]  <>  [-Session]  <String>  [-Host]  <String>  [-DefaultSetting]  <>  [-HostOnly]  <>  [-PassThru]  <>  [-LegacyContext]  <>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Removes the storage connection, transport and credential settings from the configuration repository for one or more storage system or virtual storage server.Related cmdlets: Set-SdStorageConnectionSetting and Get-SdStorageConnectionSetting
Name Description Required? Pipeline Input Default Value
StorageSystem
Specifies the name or IP address of the storage system (storage controller or virtual storage server) for which you want to retrieve connection settings.
true
true (ByPropertyName)
HostOnly
Specifies that you want to remove the storage system credentials only on the cluster node you specify. The default behavior is that HostOnly is not specified, and your storage credential settings are removed from all the nodes in a cluster.
false
PassThru
Indicates the output setting objects that you removed from the configuration. These objects are written to the pipeline for further processing.
false
false
LegacyContext
For internal use only.
false
false
Session
false
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
All
Indicates that you want to remove all connection settings, including the default settings, from the configuration repository.
true
DefaultSetting
Indicates that you want to remove the default storage system connection settings.
true
false
Example 1: Removing named connection settings
 PS C:\> Remove-SdStorageSystemSetting -StorageSystem vmStorageServer,sqlServer -PassThru
This example syntax removes the specified vmStorageServer and sqlServer storage system connection settings.
Example 2: Removing all connection settings
 PS C:\> Remove-SdStorageConnectionSetting -All -PassThru
This example syntax removes all the connection settings, including the default connection settings.
Example 3: Removing default storage connection settings
 PS C:\> Remove-SdStorageConnectionSetting -DefaultSetting -PassThru
This example syntax removes the default storage system connection settings. You can use the default settings to attempt a connection to any system that is not explicitly configured.
Example 4: Removing pipeline storage connection settings
 PS C:\> $settings = Get-SdStorageConnectionSetting
$settings | Remove-SdStorageConnectionSetting -PassThru -confirm:$false
This example syntax retrieves the existing storage connection settings. In this case, they are "vmStorageServer" and "sharePointServer". Then the example pipes those names as the connection settings to be removed. Because the confirm value is false, there is no confirmation prompt and the PassThru switch means it outputs the objects removed.
