SnapCenter cmdlets
Remove-SmResourceGroup
Removes a resource group.
Syntax
Remove-SmResourceGroup [-ResourceGroupNames]  <String>  [-Force]  <>
Detailed Description
Enables you to delete a resource group from SnapCenter based on the resource group name provided.
Name Description Required? Pipeline Input Default Value
ResourceGroupNames
true
true (ByPropertyName)
Force
false
- Example 1: Removes a resource group by the resource group name -
 Remove-SmResourceGroup -ResourceGroupNames RG2
This example syntax removes a resource group from SnapCenter based on the resource group name provided.
Are you sure you want to delete the Resource Group selected?Resource Group will be removed from all the member hosts of the Resource Group. The backups of the Resource Group will be deleted when the Resource Group is removed. Also all the association of policy with this Resource Group will be detached.
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): Y
- Example 2: Removes the resource group by resource group name without a confirmation dialogue. -
 Remove-SmResourceGroup -ResourceGroupNames RG2 -Confirm:$false
