SnapCenter 4.8 cmdlets
Set-SdDiskDriveLetter
Changes the Windows disk drive letter.
Syntax
Set-SdDiskDriveLetter [-OldDiskDriveLetter]  <String>  [-NewDiskDriveLetter]  <String>  [-Host]  <String>
Detailed Description
Changes the Windows disk drive letter. This command is supported only for dedicated and shared disk, and not applicable for CSV disk.
Name Description Required? Pipeline Input Default Value
OldDiskDriveLetter
Specifies the drive letter where the disk is mounted currently using the format: D:, D:\
true
true (ByPropertyName)
NewDiskDriveLetter
Specifies the new drive letter where the disk should be mounted using the format: D:, D:\
true
Host
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine.
false
Example 1: Changing a Windows Disk Drive Letter
 PS C:\> Set-SdDiskDriveLetter -OldDiskDriveLetter L:\ -NewDiskDriveLetter I:\
This example changes the drive letter of the specified Windows disk.
				Change-SdDiskDriveLetter
The Disk drive letter will be changed from L:\ to I:\. Do you want to continue?
[Y] Yes  [A] Yes to All  [N] No  [L] No to All  [S] Suspend  [?] Help (default is "Y"):Y
Mount point of Disk which was on L:\ has changed to I:\
