Set-SdSnapshot
Enables backup administrators to more easily attach labels to Snapshot copies and then select the secondary retention bucket by specifying the appropriate label.
Syntax
Set-SdSnapshot [-Snapshot] <String> [-Path] <Object[]> [-SnapMirrorLabel] <String> [-Session] <String> [-Host] <String> [-Snapshot] <String> [-StorageSystem] <String> [-VolumeName] <String[]> [-SnapMirrorLabel] <String> [-Session] <String> [-Host] <String>
Detailed Description
Enables backup administrators to more easily attach labels to Snapshot copies and then select the secondary retention bucket by specifying the appropriate label. You can manage the secondary Snapshot copy retention using SnapMirror policies. A SnapMirror policy defines secondary retention buckets using various rules.A policy can have a maximum of 10 rules. These rules define how many Snapshot copies must be retained for a given Snapshot label and the behavior when the threshold is reached.You can also use rules to define what happens when you reach your Snapshot copy threshold. Based on your rule definitions, either the older Snapshot copies are deleted or your updates fail.You can use this cmdlet to set the Snapshot copy label based on the secondary retention requirements.You can use this cmdlet in clustered Data ONTAP 8.2 and later. Relate cmdlets: Restore-SdSnapshot, Remove-SdSnapshot, Rename-SdSnapshot, New-SdSnapshot
| Name | Description | Required? | Pipeline Input | Default Value |
| Snapshot | Indicates the name name of the Snapshot copy to which you want the label to be attached. The Snapshot copy must exist in all the specified volumes. | true | true (ByPropertyName) | |
| Path | Specifies avolumes, logical disks, or a comma-separated list of SMB shares. You cannot mix a logical disk or mount point with SMB shares in the same input path. | true | true (ByPropertyName) | |
| SnapMirrorLabel | Specifies the label you want to attach to the Snapshot copy. If you specify an empty string, existing labels are removed. | true | true (ByPropertyName) | |
| Session | Specifies the session ID from Open-SmConnection. | false | true (ByPropertyName) | |
| Host | Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. | false | true (ByPropertyName) | |
| StorageSystem | Indicates the name of the storage system in which the Snapshot copy resides. | true | true (ByPropertyName) | |
| VolumeName | Specifies a comma-separated list of the volumes in which the specified Snapshot copy resides. | true | true (ByPropertyName) |
Example 1: Attaching a label to the specified Snapshot copy
PS C:\> Get-SdSnapshot -storagesystem prodvserver -volume voldb,vollog -snapshot salesdb_backup | Set-Sdsnapshot -label monthly
In this example syntax, you attach labels to the specified Snapshot copies.
Example 2: Making a Snapshot copy and attaching a label to it
PS C:\> New-SdSnapshot \\SQLFileserver\DBShare,\\SQLFileserver\LogShare -Snapshot salesbackup -UpdateMirror | set-Sdsnapshot -Label weekly
In this example, you make a Snapshot copy of the specified shares, attach a weekly retention label, and update the mirror relationship.
Example 3: Getting secondary backups and changing their retention label
PS C:\> Get-SdSnapshot \\SQLFileserver\DBShare,\\SQLFileserver\LogShare -GetSecondarySnapshots | set-Sdsnapshot -label monthly
In this example, you get secondary backups and change their retention labels.
 PDFs
PDFs
