SnapCenter cmdlets
Set-SdStorageSize
Expands or shrinks the size of a Windows disk.
Syntax
Set-SdStorageSize [-Path]  <String>  [-Size]  <String>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Path
Specifies the drive letter or mount point of the file system you want to resize.
true
true (ByPropertyName)
Size
Specifies the size to which you want to expand or shrink your Windows disk.
true
false
Session
Specifies the session ID from Open-SmConnection.
false
Host
Specifies the name of the computer or host on which the SnapDrive service you want to perform the operation runs. The default is your local machine.
false
Example 1: Resizing a CSV
 PS C:\> Set-SdStorageSize -path C:\ClusterStorage\Volume1\ -Size 1.1G -Verbose
This example syntax resizes a CSV.
Example 2: Resizing a disk without a mount point
 PS C:\> Set-SdStorageSize -Path D:\Mount -Size 10G -Shrink -Verbose
This example syntax resizes a drive without a mount point.
Example 3: Resize a drive
 PS C:\> Set-SdStorageSize -Path M:\ -Size 10G -Verbose
This example syntax resizes a drive.
