SnapCenter cmdlets
Set-SmDownloadRepository
Modifies the location of the installation package download repository.
Syntax
Set-SmDownloadRepository [-Path]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
Path
New plug-in repository path.
true
true (ByPropertyName)
Example 1: Modifying the installation download repository location
 Set-SmDownloadRepository -Path "c:\inetpub\wwroot\SnapCenter\Repository"
This example syntax specifies a new repository location.
