Set-SmMaintenanceMode
Sets a host to maintenance or production mode.
Syntax
Set-SmMaintenanceMode [-HostNames] <String> [-MaintenanceStatus] <SmMaintenanceStatus>
Detailed Description
Sets a host to maintenance or production mode. No scheduled jobs are executed for a host in maintenance mode.
| Name | Description | Required? | Pipeline Input | Default Value |
HostNames |
The names of the hosts for which you want to change the maintenance mode. |
true |
true (ByPropertyName) |
MaintenanceStatus |
Specifies the maintenance status of the specified hosts. The maintenance status is Production or UnderMaintenance. |
true |
Example 1: Setting a host to production mode
Set-SmMaintenanceMode -HostNames @("SQL_Host") -MaintenanceStatus Production
This example syntax sets the specified host to production mode.
Example 2: Setting multiple hosts to maintenance mode
Set-SmMaintenanceMode -HostNames @("SQL_Host", "Verification_Host") -MaintenanceStatus UnderMaintenance
This example syntax sets the specified hosts to maintenance mode.
