SnapCenter 4.8 cmdlets
Set-SmRepositoryConfigSettings
Enables you to set MySQL High Availability repository configuration settings for the SnapCenter Server host.
Syntax
Set-SmRepositoryConfigSettings [-NLBClusterIP]  <String>  [-NLBNodeIPs]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
NLBClusterIP
Specifies the NLB Cluster IP address to which the SnapCenter Server NLB host is configured.
true
true (ByPropertyName)
NLBNodeIPs
Specifies the list of NLB node IP addresses that are part of the NLB Cluster.
true
Example 1: Set MySQL High Availability repository configuration settings
 Set-SmRepositoryConfigSettings -NLBClusterIP 10.236.221.0 -NLBNodeIPs 10.236.221.10,10.236.221.11
This example syntax sets the MySQL High Availability repository configuration settings.
