SnapCenter 4.8 cmdlets
Set-SmResourceGroup
Modifies a resource group.
Syntax
Set-SmResourceGroup [-ArchivedLocators]  <Hashtable[]>  [-ResourceGroupName]  <String>  [-PluginCode]  <PluginCode>  [-EnableEmail]  <>  [-EmailPreference]  <SmEmailNotificationPreference>  [-RemoveCustomSnapShot]  <>  [-BackupServers]  <SmBackupServer>
Detailed Description
Modifies a resource group. You can modify policies, schedules, verification schedules, and resources associated with the resource group.
Name Description Required? Pipeline Input Default Value
ArchivedLocators
Specifies in a hashtable the secondary storage system details for each unique primary storage system resource in the resource group. For example:-ArchivedLocators @{Primary="my_vs1:my_vol_iscsi";Secondary="my_vs1:my_vol_iscsi_SECONDARY"}
false
true (ByPropertyName)
ResourceGroupName
Specifies the name of the resource group that you want to modify.
true
PluginCode
Specifies the plug-in code of the host for which you are modifying a backup resource group. Valid values are SCSQL, SCW, and SCO.
true
EnableEmail
Specifies whether to enable or disable email.
false
false
EmailPreference
Specifies when you will receive e-mail notifications.Possible values: Always, Never, OnError, OnErrorOrWarning.
false
false
false
BackupArchiveLogsAfterRecentMissingOne
This option is only valid for SCO plugin code. Specifies that you want to backup archive log files, which are created after the most recent missing archive log files and ignore the files created prior to it. If this option is not specified, then all archive log files except the missing archive log files are be backed up.
false
ExcludeArchiveLogPathsFromBackup
This option is only valid for SCO plugin code. Specifies the archive log destinations to be excluded from backup. Archive log files present in the specified destinations will be excluded during log backup. Multiple entries can be specified using comma separated list. For example: -ExcludeArchiveLogPathsFromBackup '/arch/logs/on/local/disk1, /arch/logs/on/local/disk2'.
false
BackupServers
false
Resources
Specifies the list of resources to be associated with the resource group.You must provide the resource information in a hashtable, and it must contain the resource name and type, and the host on which it is located. For example,@{"Host"="localhost";"Type"="SQL Database";"Names"="Instance\Database"}For instance-level backup @{"Host"="localhost";"Type"="SQL Instance";"Names"="Instance"}For availability group backup @{"Host"="localhost";"Type"="SQL Availability Group";"Names"="AG1"}Valid Type values are: SQL Database, SQL Instance, SQL Availability Group.You can include comma-separated values for Names. For Oracle Database, the format is @{"Host"="host.example.com";"Oracle Database"="db1,db2,.."}. For Oracle Application Volume, the format is @{"Host"="host.example.com";"Application Volume"="appVol1,appVol2,.."}.
true
Specifies an optional description for the new resource group.
false
Tag
Enables you to apply a unique tag to help identify the resource group.
false
Policies
Specifies the list of policies associated with the resource group. Multiple policies can be added as a comma-separated list.
false
SchedulerCredentialName
false
SchedulerInstance
Specifies the SQL Server Instance where the schedule is created and managed. This is mandatory if the policy has SQL scheduler enabled.
false
VerificationServers
Specifies the list of verification servers to be associated with the resource group. Multiple verification servers can be added as a comma-separated list. This parameter is only required when you want to verify backups for SnapCenter Plug-in for Microsoft SQL Server resource groups.
false
CustomSnapshotFormat
Specifies that you want to use a custom Snapshot copy naming format. By default, a timestamp is appended to the Snapshot copy name. Valid values for CustomSnapshotFormat are : $ResourceGroup, $Policy, $HostName, $ScheduleType, $CustomText
false
CustomText
Specifies the custom text in the custom Snapshot copy naming format.
false
DeleteBackupForDetachPolicies
Deletes backups for the detached policies.
false
Schedules
Specifies the schedule parameters to be used in the resource group. Schedule parameters can include the policy name, schedule type, schedule start and end times. You can specify multiple schedules in a comma-separated list, for example:-Schedules @{"PolicyName"="BackupPolicy";"ScheduleType"="OneTime"}, @{"PolicyName"="BackupPolicy";"ScheduleType"="Hourly";"StartTime"=" 05/27/2016 6:13 PM";"EndTime"="'05/27/2016 6:30 PM'"}
false
SchedulerType
Specifies the scheduler type. Possible values are Windows, SQL, None.
false
VerificationSchedules
Specifies the verification schedules you want to add to the resource. The verification schedule includes the following parameters:"VerificationType" which defines if and when verification is performed. The following values are available:VERIFY_SCHEDULEDVERIFY_AFTER_BACKUPNONE"ScheduleType" represents the schedule type for the verification."BackupScheduleType" represents the schedule type for the backup-VerificationServers "WIN-DVGQDI73QR6" needs to be provided in the above command if we are creating verification enabled resource group for SCSQL plugin.Example:-VerificationSchedules @{"BackupScheduleType"="Hourly";"DeferredBackupCount"="1";"VerificationType"="VERIFY_SCHEDULED";"VerifyOnSecondary"="true";"BackupPolicyName"="sco_20july";"ScheduleType"="Weekly";"DaysOfTheWeek"="Monday";"StartTime"="20-Jul-16 6:42:12 PM";"EndTime"="25-Jul-16 6:42:12 PM"}
false
ConsistencyGroupSnapshot
false
ConsistencyGroupWaflSync
false
ConsistencyGroupTimeOut
false
SnapShotCreateCommand
false
UseFileSystemConsistentSnapshot
false
UseSnapcenterWithoutFileSystemConsistency
false
PreAppQuiesceCmd
false
PostAppQuiesceCmd
false
AppQuiesceCmd
false
AppUnQuiesceCmd
false
PreAppUnQuiesceCmd
false
PostAppUnQuiesceCmd
false
PreExitCmd
false
PreSnapshotCmd
false
PostSnapshotCmd
false
AppIgnoreError
false
UseExternalSnapShot
false
ExternalSnapshotRegex
false
ConfigParams
false
Example 1: Modifying a custom Snapshot copy format
 Set-SmResourceGroup -ResourceGroupName PayrollDataset -CustomSnapShotFomat '$CustomText
          $Dataset$Policy$HostName' -CustomText NetApp
This example syntax modifies a custom Snapshot copy format.
Example 2: Modifying a HANA custom Snapshot copy format
 Set-SmResourceGroup -ResourceGroupName "RG1" -PluginCode HANA
          -Resources @{"Host"="hanahost01.testlab.netapp.com";"Uid"="MDC\R71"}
          -CustomSnapShotFomat '$CustomText $Dataset$Policy$HostName' -CustomText NetApp
This example syntax modifies a HANA custom Snapshot copy format.
Example 3: Deleting associated backups when detaching a policy from a resource group
 Set-SmResourceGroup  -ResourceGroupName "RG1" -PluginCode SCSQL -Resources
          @{"Host"="WIN-DVGQDI73QR6";"Type"="SQL Database";"Names"="WIN-DVGQDI73QR6\INST_SQL12\DB123} -Policy poly_full
          -DeleteBackupForDetachPolicies 1
This example syntax modifies a resource group to delete the backups associated with the policy when detaching the policy.
Example 4: Modifying an Oracle Plug-in resource group
 Set-SmResourceGroup -ResourceGroupName 'mixedRG' -Resources @(@{"Host"="R809278EA03V1.HNK2.com";"Oracle Database"="DB11,DB12"},@{"Host"="R8092776CF4V1.HNK2.com";"Application Volume"="appVol1,appVol3"}) -plugincode 'SCO' -Policies 'appVolPolicyModified'
This example syntax modifies the policy and resources of an Oracle Plug-in resource group.
