Add-SmPolicy
Creates a new backup policy.
Syntax
Add-SmPolicy [-PolicyName] <String> [-PolicyType] <SmPolicyType> [-PluginPolicyType] <PluginCode> [-Description] <String>
Detailed Description
Creates a new backup policy. A policy is a set of rules governing backup jobs. A Policy includes backup type, verification schedules, and pre-script and post-script arguments.
Name | Description | Required? | Pipeline Input | Default Value |
PolicyName |
Specifies the name of the policy you are adding. |
true |
true (ByPropertyName) |
PolicyType |
Specifies the policy type. Valid value is Backup. |
true |
PluginPolicyType |
Specifies the type of plug-in. You need to specify a plug-in type because policies are settings that are specific to one type of plug-in. For example, if you want to create a policy for resources contained in a SnapCenter Plug-in for Microsoft SQL Server dataset, the plug-in types are SCSQL and SCO.Available plug-in policy types include SCSQL, SCO, SCU, HANA, SCW, SCE. |
true |
Description |
Provides an optional description of the policy you are adding. |
false |
UtmType |
Type of up to the minute (UTM) retention settings to apply to log backups. Possible values are days and count. |
false |
UtmCount |
Up to the minute (UTM) retention by count. |
false |
UtmDays |
Up to the minute (UTM) retention by days. |
false |
SqlBackupType |
SQL backup type. Possible values are LogBackup, FullBackup and FullBackupAndLogBackup. |
true |
DatabasesPerGroup |
Maximum number of databases in a group. This is applicable only for full backup. |
false |
CopyOnlyBackup |
Determines whether the full backup is a copy only backup. |
false |
AGBackupType |
Availability Group backup type. Possible values are UsePreferredBackupReplica and UseSpecifiedBackupReplica. |
false |
AGBackupReplicaType |
Availability Group backup replica type. Possible values are Primary, Secondary and All. |
false |
AGBackupPriorityMinimum |
Availability Group backup minimum priority. |
false |
AGBackupPriorityMaximum |
Availability Group backup maximum priority. |
false |
CreateLogFolderSnapshot |
Creates a Log folder Snapshot copy. |
false |
EnableLogFolderSnapshotRetention |
Enables log folder Snapshot copy retention. |
false |
DeleteLogFolderSnapshotInExcess |
false |
DeleteLogFolderSnapshotOlderThan |
Deletes log folder Snapshot copies that are older than the specified number of days. |
false |
VerifyLogBackup |
Enables log backup verification after backup. |
false |
DBCC_NOINDEX |
DBCC options NOINDEX. |
false |
false |
DBCC_ALL_ERRORMSGS |
DBCC options ALL_ERRORMSGS. |
false |
DBCC_NO_INFOMSGS |
DBCC options NO_INFOMSGS. |
false |
DBCC_TABLOCK |
DBCC options TABLOCK. |
false |
DBCC_PHYSICALONLY |
DBCC options PHYSICALONLY. |
false |
UpdateSnapMirrorAfterbackup |
Update SnapMirror copy after backup. This option is not applicable for SAP HANA policy of File-Based Backup type. |
false |
UpdateSnapVaultAfterbackup |
Update SnapVault copy after backup. This option is not applicable for SAP HANA policy of File-Based Backup type. |
false |
MirrorVaultUpdateRetryCount |
Number of retries to ensure SnapMirror or SnapVault update is triggered. |
false |
SnapVaultLabel |
Label for SnapVault. |
false |
AllowSavedStateBackup |
Allow saved state backup. |
false |
DeleteBackupInExcess |
Delete backup in excess of specified days, it is applicable to only SnapCenter Plug-in for VMware vSphere, if it is used with other plug-ins it will be ignored. |
false |
DeleteBackupOlderThan |
Delete backups older than specified days, it is applicable to only SnapCenter Plug-in for VMware vSphere, if it is used with other plug-ins it will be ignored. |
false |
PreScriptCommandVerification |
Specifies the path of the prescript that should be run before the backup operation. |
false |
PreScriptArgumentsVerification |
Specifies the prescript arguments. |
false |
PostScriptCommandVerification |
Specifies the path of the postscript that should be run after the backup operation. |
false |
PostScriptArgumentsVerification |
false |
ScriptTimeOutVerification |
false |
ScheduleType |
The schedule type. Possible values are None, Hourly, Weekly, Daily, and Monthly. |
false |
RetentionSettings |
Specifies in a hashtable the retention settings for the policy. |
false |
PreScriptCommand |
Prescript file UNC path with proper privileges for scripts accessibility, (‘\\\\server\\share\path\\file’ for Universal Naming Convention (UNC) names). |
false |
PreScriptArguments |
false |
PostScriptCommand |
Postscript file UNC path with proper privileges for scripts accessibility, (‘\\\\server\\share\path\\file’ for Universal Naming Convention (UNC) names). |
false |
PostScriptArguments |
Specifies postscript arguments. |
false |
ScriptTimeOut |
Specifies script timeout value in seconds. |
false |
VerificationScheduleType |
false |
DeleteCloneOnScheduleExpiry |
Removes a clone during the last run of a scheduled job.If this parameter is not set, then the last run of a schedule also runs a clone life cycle and creates a cloned database.This parameter does not apply to jobs that are not scheduled or to one time job schedules. |
false |
BackupPolicyName |
Specifies the backup policy name. |
true |
CloneType |
Specifies the clone type. Possible values are Primary and Secondary. |
false |
VerifyOnSecondary |
Specifies whether to verify on secondary or not. |
false |
false |
NumOfBackups |
Number of backups to be verified. |
false |
false |
PluginParams |
false |
DominoChangeInfoPath |
false |
DominoDatabaseType |
false |
DominoIniPath |
false |
DominoRestoreFilePath |
false |
DominoRestoreTime |
false |
Lotus |
false |
NotesExecDirectory |
false |
DominoDisableReplication |
false |
DominoIgnoreCorruptedDB |
false |
DBMCliCmd |
false |
HandleLogWriter |
false |
MaxDBBGServerPrefix |
false |
MaxDBUpdateHistLog |
false |
SQLCliCmd |
false |
XUserEnable |
false |
DB2Cmd |
false |
SybaseISQLCmd |
false |
SybaseManifest |
false |
SybaseManifestDelete |
false |
SybaseManifestFormat |
false |
SybaseTranDump |
false |
SybaseTranDumpCompress |
false |
SybaseTranDumpFormat |
false |
BackupType |
This is a SAP HANA database specific parameter. Specifies the type of SAP HANA backup. The possible values are FileBasedBackup and SnapshotBasedBackup. |
true |
OracleBackupType |
Specifies the Oracle backup type. Backup types include Online, Offline mount, and Offline shutdown. |
true |
OracleBackupScope |
This option is only valid when the backup type is Online. Backup scope values are Full, Data, and Log. |
true |
OracleSkipPDBSaveState |
Enables you to skip PDB save state. This parameter is only available when you select Offline shutdown backup type. Values are True or False. |
false |
DeleteAllArchiveLogs |
Prunes (deletes) all archive logs after Full or Log backups. |
false |
DeleteArchiveLogsOlderThan |
Prunes (deletes) archive logs older than a specified number of days. This parameter supports the use decimals to enable you to specify a fraction of a day. For example, 2.5 represents 2 days and 12 hours, and 0.04 represents 1 hour. |
false |
DeleteArchiveLogFromAllDestination |
This parameter enables pruning of archive logs on a specified destination. If the value is True, archive logs are pruned on all destinations. If the option is False, archive logs are pruned only on backed up destinations. |
false |
DeleteArchiveLogBackupInExcess |
Deletes archive log backup in excess of the specified backup count. |
false |
DeleteAchiveLogBackupOlderThan |
Deletes archive log backups that are older than the specified number of days. This parameter supports the use decimals to enable you to specify a fraction of a day. For example, 2.5 represents 2 days and 12 hours, and 0.04 represents 1 hour. |
false |
CatalogBackupWithOracleRMAN |
Specifies that you want to catalog backup using Oracle Recovery Manager (RMAN). |
false |
ScwBackupType |
The SnapCenter Plug-in for Windows backup type. Values are ApplicationConsistent, FilesystemConsistent and CrashConsistent. |
true |
SceBackupType |
true |
UtmCounts |
false |
BackupTruncatedTransactionLog |
false |
BackupActiveCopies |
false |
BackupCopiesOnServer |
false |
Example 1: Creating a new hourly policy with scheduler type as SQL
Add-SmPolicy -PolicyName TESTPolicy - PluginPolicyType SCSQL -PolicyType Backup -SqlBackupType FullBackup -ScheduleType Hourly -Verbose –SchedulerType SQL
This example syntax creates a new hourly policy with the SQL scheduler type.
Example 2: Creating an Oracle policy that prunes all archive logs on all destinations, and deletes archive log backups in excess of 5
Add-SmPolicy -PolicyName 1 -PolicyType Backup -PluginPolicyType SCO -OracleBackupType ONLINE -OracleBackupScope FULL -DeleteAllArchiveLogs $true -DeleteArchiveLogFromAllDestination $true -DeleteArchiveLogBackupInExcess 5
This example syntax creates an Oracle policy that prunes all archive logs on all destinations, and deletes archive log backups in excess of 5.
ApplySnapvaultUpdate: False ApplyRetention : False RetentionCount : RetentionDays : ApplySnapMirrorUpdate : False SnapVaultLabel : MirrorVaultUpdateRetryCount : 3 AppPolicies : {} Description : PreScriptPath : PreScriptArguments : PostScriptPath : PostScriptArguments : ScriptTimeOut : 60000 DateModified: 10/5/2015 2:17:57 PM DateCreated : 10/5/2015 2:17:57 PM Schedule: SMCoreContracts.SmSchedule PolicyType : Backup PluginPolicyType: SCO Name: 1 Type: Id : 99 Host: UserName: Passphrase : Deleted : False Auth: SMCoreContracts.SmAuth IsClone : False CloneLevel : 0 Hosts : {} SmOracleBackupType : ONLINE SmOracleBackupScope: FULL SmOraclePDBSaveState : True PruneArchiveLog: True PruneArchiveLogType: AllLogs PruneArchiveLogOlderThanDays : PruneArchiveLogDestinationType : AllDestinations DeleteArchiveLogBackup : True ArchiveLogBackupRetentionType : CountBase DeleteArchiveLogBackupCounts : 5 DeleteArchiveLogBackupDays : Name : Type : Id : Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 Hosts : {}
Example 3: Creating a policy for custom plugin DB2 with daily schedule type
Add-SMPolicy -PolicyName 'DB2_DAILY_POLICY' -PolicyType 'Backup' -PluginPolicyType DB2-retentionsettings @{"BackupType"="DATA";"ScheduleType"="DAILY";"RetentionCount"='3'} -description 'DB2 daily schedule policy' -scheduletype 'DAILY'
This example syntax creates a daily scheduled policy for custom plug-in DB2 with retention count 3
ApplyRetention : True ApplySnapMirrorUpdate : False ApplySnapvaultUpdate: False MirrorVaultUpdateRetryCount : 3 RetentionCount : 3 RetentionDays : 0 SnapVaultLabel : AppPolicies : {} DateCreated : 8/22/2016 9:37:43 AM DateModified: 8/22/2016 9:37:43 AM Description : DB2 daily schedule policy PluginPolicyType: DB2 PolicyType : Backup PostScriptArguments : PostScriptPath : PreScriptArguments : PreScriptPath : Schedules : {} Schedule: SMCoreContracts.SmSchedule ScriptTimeOut : 60 Name: DB2_DAILY_POLICY Type: Id : 18 Host: UserName: Passphrase : Deleted : False Auth: SMCoreContracts.SmAuth IsClone : False CloneLevel : 0 Hosts : {} TaskName : Hosts : {} StartTime : DaysoftheMonth: MonthsofTheYear : DaysInterval : 0 DaysOfTheWeek : AllowDefaults : False ReplaceJobIfExist : False UserName : Password : SchedulerType : Daily RepeatTask_Every_Hour : IntervalDuration : EndTime : LocalScheduler: AppType : AuthMode : SchedulerSQLInstance : SMCoreContracts.SmObject MonthlyFrequency : ScheduleID: 0 PolicyId : 18 PluginName : DB2 PluginParams : SMCoreContracts.SmKeyValueCollection SmSCBackupType : DataBackup Name : Type : Id : Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 Hosts : {}
Example 4: Creating a new Windows backup policy
Add-SmPolicy -PolicyName scw_policy -PolicyType Backup -PluginPolicyType SCW -ScwBackupType CrashConsistent
This example syntax creates a new Windows backup policy.
ApplySnapvaultUpdate : False ApplyRetention : False RetentionCount : RetentionDays: ApplySnapMirrorUpdate: False SnapVaultLabel : MirrorVaultUpdateRetryCount : 3 AppPolicies : {} Description : PreScriptPath: PreScriptArguments : PostScriptPath : PostScriptArguments : ScriptTimeOut: 60 DateModified : 5/18/2016 6:36:24 PM DateCreated : 5/18/2016 6:36:24 PM Schedule : SMCoreContracts.SmSchedule PolicyType : Backup PluginPolicyType : SDW Name : scw_policy Type : Id : 1 Host : UserName : Passphrase : Deleted : False Auth : SMCoreContracts.SmAuth IsClone : False CloneLevel : 0 Hosts: {} ScwBackupType : CrashConsistent Name : Type : Id: Host : UserName : Passphrase: Deleted : False Auth : SMCoreContracts.SmAuth IsClone : False CloneLevel: 0 Hosts : {}
Example 5: Creating a new backup policy for SnapCenter Plugin for SAP HANA backup of type FileBasedBackup
Add-SmPolicy -PolicyName newpol123 -PolicyType Backup -PluginPolicyType hana -BackupType FileBasedBackup
This example syntax creates a new backup policy for SnapCenter Plug-in for SAP HANA with FileBasedBackup as the backup type.
ApplyRetention : True ApplySnapMirrorUpdate : False ApplySnapvaultUpdate: False MirrorVaultUpdateRetryCount : 0 RetentionCount : 7 RetentionDays : 0 SnapVaultLabel : AppPolicies : {} DateCreated : 3/23/2017 10:14:31 PM DateModified: 3/23/2017 10:14:31 PM Description : PluginPolicyType: hana PolicyType : Backup PostScriptArguments : PostScriptPath : PreScriptArguments : PreScriptPath : Schedules : {} Schedule: SMCoreContracts.SmSchedule ScriptTimeOut : 60 Name: newpol123 Type: Id : 39 Host: UserName: Passphrase : Deleted : False Auth: SMCoreContracts.SmAuth IsClone : False CloneLevel : 0 Hosts : {} StorageName : ResourceGroupNames : PolicyNames : Key : 0 NsmObjectID : 0 Retention Settings BackupType : DATA SchedulerType : None RetentionCount : 7 RetentionDays : 0 VerificationEnabled : False NodeName: PolicyId : 39 PluginName : hana PluginParams : SMCoreContracts.SmKeyValueCollection SmSCBackupType : FileBasedBackup Name : Type : Id : Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 Hosts : {} StorageName: ResourceGroupNames : PolicyNames: Key: 0 NsmObjectID: 0
Example 6: Creating a new backup policy for SnapCenter Plugin for SAP HANA backup of type SnapshotBasedBackup
Add-SmPolicy -PolicyName hana_snapshotbased -PolicyType Backup -PluginPolicyType hana -BackupType SnapShotBasedBackup
This example syntax creates a new backup policy for SnapCenter Plug-in for SAP HANA with SnapshotBasedBackup as the backup type.
ApplyRetention : True ApplySnapMirrorUpdate : False ApplySnapvaultUpdate: False MirrorVaultUpdateRetryCount : 3 RetentionCount : 7 RetentionDays : 0 SnapVaultLabel : AppPolicies : {} DateCreated : 3/23/2017 10:17:30 PM DateModified: 3/23/2017 10:17:30 PM Description : PluginPolicyType: hana PolicyType : Backup PostScriptArguments : PostScriptPath : PreScriptArguments : PreScriptPath : Schedules : {} Schedule: SMCoreContracts.SmSchedule ScriptTimeOut : 60 Name: hana_snapshotbased Type: Id : 41 Host: UserName: Passphrase : Deleted : False Auth: SMCoreContracts.SmAuth IsClone : False CloneLevel : 0 Hosts : {} StorageName : ResourceGroupNames : PolicyNames : Key : 0 NsmObjectID : 0 Retention Settings BackupType : DATA SchedulerType : None RetentionCount : 7 RetentionDays : 0 VerificationEnabled : False NodeName: PolicyId : 41 PluginName : hana PluginParams : SMCoreContracts.SmKeyValueCollection SmSCBackupType : DataBackup Name : Type : Id : Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0 Hosts : {} StorageName: ResourceGroupNames : PolicyNames: Key: 0 NsmObjectID: 0
Example 7: Adding a policy with a retention based on number of days
Add-SMPolicy -PolicyName 'DB2_DAILY_POLICY' -PolicyType 'Backup' -PluginPolicyType DB2- retentionsettings @{"BackupType"="DATA";"ScheduleType"="DAILY";"RetentionDays"='3'} - description 'DB2 daily schedule policy' -scheduletype 'DAILY'
