SnapCenter 4.9 cmdlets
Get-SmCredential
Gets credentials of the plug-ins that are registered with the SnapCenter Server.
Syntax
Get-SmCredential [-Name]  <String>
Detailed Description
Gets and displays the credential information of all the plug-ins that are registered with the SnapCenter Server.
Name Description Required? Pipeline Input Default Value
Name
false
true (ByPropertyName)
Example 1: Get all Credentials
 Get-SmCredential
Example 2: Get particular Credential
 Get-SmCredential -Name RunAs1
Example 3: Get particular Azure NetApp Credential
 Get-SmCredential -Name RunAsAzure1
 Output of above Get-SmCredential command:
RunAsName  : RunAsAzure1
OwnerId: 1
AuthMode   : AzureCredential
SubscriptionId : sub
ClientSecret   :
TenantId   : ten
ClientId   : cl
