SnapCenter cmdlets
Get-SmLogs
Gets SnapCenter log files.
Syntax
Get-SmLogs [-Path]  <String>  [-AllLogs]  <>  [-Path]  <String>  [-ServerLogs]  <>  [-Path]  <String>  [-JobId]  <Int64>  [-Path]  <String>  [-PluginId]  <Int64>  [-Path]  <String>  [-HostName]  <String>  [-PluginCode]  <PluginCode>
Detailed Description
Gets SnapCenter log files. Log files are returned in a .zip file. You can retrieve all SnapCenter logs, or logs for a individual plug-in or SnapCenter instance. You can also get logs for a specified job.
Name Description Required? Pipeline Input Default Value
Path
Specifies the path for the location to which you want the log .zip file to be written.
true
false
AllLogs
Indicates that you want to receive all SnapCenter logs, which include SnapCenter server, managed host, and plug-in logs.
true
false
ServerLogs
Indicates that you want to receive logs for the SnapCenter server only.
true
false
JobId
Indicates that you want to receive information for a specified job ID.
true
false
PluginId
Indicates that you want to receive information for the specified plug-in ID.
true
false
HostName
Specifies the host for the plug-in instance for which you want to retrieve logs.
false
false
PluginCode
Indicates that you want to create log settings pertaining to a specified plug-in instance. Valid plug-in values are SCSQL and SCO. For example, if you want to retrieve the SnapCenter Plug-in for Microsoft SQL Server logs, the plug-in code is SCSQL.
true
false
Example 1: Retrieving all logs
 Get-SmLogs -AllLogs -Path C:\temp\allLogs.zip
This example syntax retrieves all log files.
Example 2: Retrieving SnapCenter Server logs
 Get-SmLogs -Path C:\temp\serverLogs.zip –ServerLogs
This example syntax retrieves all Server logs.
Example 3: Retrieving plugin instance logs
 Get-SmLogs -HostName host123 -Path C:\temp\smsqlLogs.zip -PluginCode SCSQL
This example syntax retrieves all plug-in instance logs for SnapCenter Plug-in for Microsoft SQL Server.
Example 4: Retrieving logs for a designated job
 Get-SmLogs -JobId 1234 -Path C:\temp\job_1234.zip
This example syntax retrieves logs for job ID 1234.
