Get-SmPluginConfiguration
Gets the plug-in configuration for a host.
Syntax
Get-SmPluginConfiguration [-PluginCode] <PluginCode> [-HostName] <String>
Detailed Description
Gets the plug-in information for a host.
Name | Description | Required? | Pipeline Input | Default Value |
PluginCode |
The plug-in code. Valid values are SCW, SCSQL, and SCO. |
true |
true (ByPropertyName) |
HostName |
The name of the host on which the plug-in is installed. |
true |
Example 1: Getting plugin configuration information for a host
Get-SmPluginConfiguration -PluginCode SCSQL -HostName localhost
This example syntax gets the SnapCenter plug-in configuration for the specified host.
PluginInfoId : HostName : PluginName: SnapCenter Plug-in for Microsoft SQL Server PluginVersion : InstallPath : Description : VendorName: EndpointURI : http://localhost:809/SqlManagementService DateCreated : DateModified : Message : Resources : {} PluginCode: SMSQL PluginConfiguration : SMCoreContracts.SmSqlConfiguration ServiceName : DisplayName : ServiceStatus : Unavailable PluginServiceAction : None Port : 0 GUID : PluginCompatibilityStatus : None LicenseType : None LicenseKey: PluginInstallStatus : ePluginInstallStatusUnknown HostMaintenanceStatus : Production TCPPort : 0 Auth : SMCoreContracts.SmAuth
