SnapCenter 4.9 cmdlets
Get-SmPluginPackage
Gets information about plug-in packages that have been uploaded for a specific custom plug-in.
Syntax
Get-SmPluginPackage [-PluginName]  <String>
Detailed Description
Gets information about the plug-in packages that are uploaded for a specific custom plug-in.
Name Description Required? Pipeline Input Default Value
PluginName
Specifies the name of the custom plug-in for which you want to determine the uploaded plug-ins.
false
false
Example 1: Get information about a custom plugin package
 Get-SmPluginPackage -PluginName DB2
This example syntax gets all uploaded package version information of the custom plug-in named DB2.
CustomPluginName: DB2
CustomPluginVersion : 1.0
CustomPluginType:
OsInfo  : SMCoreContracts.SmOperatingSystemInfo
Resources   : {SMCoreContracts.SmSCCustomResoureceType}
RequireFileSystemPlugin : False
UploadedFileName: DB2_1.0.zip
CustomPluginDisplayName : IBM DB2
CustomPluginVersion : 2.0
CustomPluginType:
UploadedFileName: DB2_2.0.zip
