Get-SmPolicy
Retrieves details about one or more policy.
Syntax
Get-SmPolicy [-PolicyName] <String> [-DatasetName] <String>
Detailed Description
Retrieves details about one or more policy. You can retrieve details about a specific policy or about all policies in a resource group.
Name | Description | Required? | Pipeline Input | Default Value |
PolicyName |
Specifies the name of the policy for which you want details. |
false |
true (ByPropertyName) |
DatasetName |
Specifies a dataset. This parameter retrieves policy details for each policy in the dataset. |
false |
Example 1: Retrieving information about a policy
Get-SmPolicy -PolicyName "Full Backup with Replication"
This example syntax gets information about the specified policy.
ApplySnapvaultUpdate: True ApplyRetention : True RetentionCount : 2 RetentionDays : 0 ApplySnapMirrorUpdate : True SnapVaultLabel : OneTime MirrorVaultUpdateRetryCount : 7 AppPolicies : {} Description : PreScriptPath : PreScriptArguments : PostScriptPath : PostScriptArguments : ScriptTimeOut : 60000 DateModified: 6/10/2015 7:18:50 PM DateCreated : 6/8/2015 11:03:07 PM Schedule: SMCoreContracts.SmSchedule PolicyType : Backup PluginPolicyType: SMSQL Name: Full Backup with Replication Type: Id : 1 Host: UserName: Passphrase : Deleted : False Auth: SMCoreContracts.SmAuth IsClone : False CloneLevel : 0 SmSqlBackupType: FullBackup CopyOnlyBackup : False CopyOnlyLogBackup : False UtmType: None UtmCounts : 7 UtmDays: 14 RunLiveDBCCBefore : False RunLiveDBCCAfter : False RetentionType : TruncateLog: True VerificationAfterBackup: False TransLogMark : TransLogDescription: AGBackupType : UsePreferredBackupReplica AGReplicaType : Primary AGBackupPriorityMin: 1 AGBackupPriorityMax: 100 VerifyLogBackup: False MaxDbConcurrentBackup : 35 CreateLogFolderSnapshot: True DeleteLogFolderSnapshot: False LogFolderSnapshotRetentionType : LogFolderSnapshotCounts: 0 LogFolderSnapshotDays : 0 DeleteLogInShare : False LogInShareRetentionType: LogInShareCounts : LogInShareDays : CopyLogToShare : False CopyLogToShareType : VerifyPolicy : SMCoreContracts.SmVerificationPolicy Name : Type : Id : Host : UserName : Passphrase : Deleted: False Auth : SMCoreContracts.SmAuth IsClone: False CloneLevel : 0
Example 2: Retrieving information for policies in a dataset
Get-SmPolicy -DatasetName DB_ON_I_S_DRIVE_ds
GetSmPolicy for custom DB2 plugin
Get-SmPolicy -PolicyName SECONDARY_SNAPMIRROR
Custom plug-in DB2 policy with SnapMirror update enabled
BackupType : DATA SchedulerType : None RetentionCount : 24 RetentionDays : 0 VerificationEnabled : False ApplyRetention : True ApplySnapMirrorUpdate : True ApplySnapvaultUpdate: False MirrorVaultUpdateRetryCount : 3 RetentionCount : 24 RetentionDays : 0 SnapVaultLabel : AppPolicies : {} DateCreated : 8/21/2016 4:23:20 PM DateModified: 8/21/2016 4:23:20 PM Description : testPolicy PluginPolicyType: DB2 PolicyType : Backup PostScriptArguments : PostScriptPath : PreScriptArguments : PreScriptPath : Schedules : {} Schedule: SMCoreContracts.SmSchedule ScriptTimeOut : 60 Name: SECONDARY_SNAPMIRROR Type: Id : 23 Host: UserName: Passphrase : Deleted : False Auth: SMCoreContracts.SmAuth IsClone : False CloneLevel : 0 Hosts : {} PolicyId : 23 PluginName : DB2 PluginParams : SMCoreContracts.SmKeyValueCollection Name : Type : Id : Host : UserName : Passphrase : Deleted : False Auth : SMCoreContracts.SmAuth IsClone : False CloneLevel : 0 Hosts: {}
