SnapCenter 4.9 cmdlets
Get-SmResources
Discovers plug-in resources.
Syntax
Get-SmResources [-PluginCode]  <PluginCode>  [-HostName]  <String>  [-UseKnownResources]  <SwitchParameter>  [-AppObjectType]  <String>  [-AppObjectId]  <String>  [-IsDAG]  <SwitchParameter>  [-InformationAction]  <ActionPreference>  [-InformationVariable]  <String>  [-WhatIf]  <SwitchParameter>  [-Confirm]  <SwitchParameter>
Detailed Description
Discovers plug-in resources. For SnapCenter Plug-in for Microsoft SQL Server, resources include databases, Availability Groups, and SQL Server instances. You can query one host at a time and return information about any plug-in instances installed on that host. You can use this cmdlet to get detailed information about resources located on the specified host.For SnapCenter Plug-in for Oracle Database, resources include Oracle databases and application volumes This is useful for creating appropriate disk and SMB shares and to include resources in datasets for later data protection.If a request times out when running this cmdlet, you can add the following rest timeout value key to the out from PowerShell config file located at "C:\Windows\System32\WindowsPowerShell\v1.0\Modules\SnapCenter\SnapManager.PSModule.dll.config": <add key="RESTTimeout" value="10800000" />
Name Description Required? Pipeline Input Default Value
PluginCode
The name of the plug-in for which you want to discover resources. Possible inputs include SCSQL, SCW, SCO, HANA, SCU, SCE, and SP.
true
true (ByPropertyName)
HostName
Specifies the host name. You can query one host at a time.
true
UseKnownResources
Indicates that you want to return the cached resources. You can use this parameter when you have already queried resources from the SnapCenter GUI. In this case, you receive information only about the already discovered resources. You can use this parameter for resource verification.Oracle application volume resources are manually created by the user. These resources will always be obtained from the SnapCenter database because discovery on host is not applicable for them.
false
AppObjectType
Specifies the type of application object. For example, instance, database, or a SAP HANA SingleContainer or MultipleContainers. For SnapCenter Plug-in for Oracle Database, valid object types are Database and ApplicationVolume.
false
AppObjectId
Specifies the AppObjectId of resource. For example, -AppObjectId MVA-RX200-S13\SQLEXPRESS\DB16. For Oracle databases and application volume resources, the ID is of the format HostName\ResourceName.
false
IsDAG
Required parameter that enables SnapCenter to discover Microsoft Exchange Database Availability Groups (DAGs) when you use the SnapCenter Plug-in for Microsoft Exchange Server.
false
WhatIf
false
false
Confirm
false
false
DatabaseName
SAP HANA database name.
false
true (ByValue, ByPropertyName)
ListStorageFootprint
false
SID
This is a SAP HANA database specific parameter. A SAP HANA system is identified by aunique 3 letter system ID (SID). For example, ABC.
false
ResourceType
false
TenantDatabaseName
This is a SAP HANA database specific parameter. It is the name of the tenant database for SAP HANA Multitenant Database.
false
ResourceName
This can be used to filter resources by their names
false
Example 1: Discovering resources on a host
 Get-SmResources -HostName 'vise-f6.sddev.mycompany.com' -PluginCode MSFT_SQL
This example syntax discovers the resources for the Microsoft SQL plug-in on the specified host.
PluginCode OperationResults
MSFT_SQL {SMCoreContracts.SmObjectOperationResult, SMCoreContract…​
Example 2: Listing storage content of custom DB2 plugin resource
 Get-SmResources -HostName 'sccorelinux61.sccore.test.com' -PluginCode DB2 -AppObjectName financeDB -ListStorageFootprint
This example syntax lists resource details along with StorageFoot print details of the custom plug-in resource named financeDB of DB2.
Completed Discovering resources: Job Id [123]
ResourceName : financeDB
ResourceVersion  :
ResourceId   : sccorelinux61.sccore.test.com\Db2\financeDB
ResourceType : Instance
Protected: No
RunAsName:
ResourceSettings :
MountPaths   :
StorageFootPrint : StorageResourceType : SDStorageDir, StorageResource : financeDB :/vol/SM1_SRC_sccorelinux61_sccore_test_com
Example 3: Listing SAP HANA databases of type SingleContainer
 Get-SmResources -HostName 'scspr0204312001.gdl.englab.netapp.com' -PluginCode hana -AppObjectType SingleContainer
This example syntax lists all SAP HANA databases of resource type SingleContainer.
Completed Discovering Resources: Job Id [564]
DatabaseName : NonMDC6
SID  : LMN
UserStoreKeys: bG1uOGfG3efS1yJZQMqOttTQH5C283MUtNTlOHUlIYhUbAH+zBtCpXAr/v89mO2Is9IoQuNKjOOGeKD/iv4vYaP+2hK0VNM8YOf8zAU58u24RZGTrLjcLZX0OeH0JwPgGZ5Ljml629LkU7ArBMfWXokq6Q==
FileBackupPath   : /hana/shared/LMN/HDB01/backup/data
FileBackupPrefix : SnapCenter_
OSDBUser :
ResourceId   : scspr0204312001.gdl.englab.netapp.com\hana\LMN
ResourceUid  : LMN
PluginName   : hana
Host : scspr0204312001.gdl.englab.netapp.com
ResourceType : SingleContainer
Protected: No
RunAsName:
ResourceSettings :
MountPaths   :
Example 4: Listing SAP HANA databases of type Multitenant Database Container
 Get-SmResources -HostName 'scspr0204312001.gdl.englab.netapp.com' -PluginCode hana -AppObjectType MultipleContainers
This example syntax lists SAP HANA databases of resource type MultipleContainers.
Completed Discovering Resources: Job Id [565]
DatabaseName   : NewRes1
SID: BGB
UserStoreKeys  : YmdiOd9V1LuiyloAsPoQhXb1I32XN8mu4kmsXUT1eWA/wsEBIr0YbxAniqNQCWPJxot/bw24xEfTr1IUOuP8wXGP4t/DluFo4HfNIYIpEAQ9BuK9ehMQagGY9DwbsvtTrrueVzPCi0E4LAfV4+WsLdLaow==
FileBackupPath : /hana/shared/PPP/HDB01/backup/data
OSDBUser   :
TenantDatabaseName : hhh
TenantType : SingleTenant
ResourceId : scspr0204312001.gdl.englab.netapp.com\hana\BGB\hhh
ResourceUid: BGB\hhh
PluginName : hana
ResourceType   : MultipleContainers
Protected  : No
RunAsName  :
ResourceSettings   :
MountPaths :
Example 5: Listing all SAP HANA resources of specified host
 Get-SmResources -PluginCode 'hana' -HostName 'schana02.gdl.englab.netapp.com' -UseKnownResources
This example lists all the SAP HANA databases of a selected host.
Completed Discovering Resources: Job Id [21]
DatabaseName: R57
SID : R57
UserStoreKeys   : cjU3uItRwnENhBzpUwKFGMsPL+sWzrS0LwLvh+BVhDJEh+hxGEBF00tcKka6ElLUjyXEPDULjXdVqw6GmlkIr+UuIa4Zq+pnGKlt0zRbM6E1ZxE8k6r8HElNgHrjY3JUsUvBS7RNQlOirVC6R2n93Qfd9A==
FileBackupPath  :
FileBackupPrefix: SnapCenter_
OSDBUser: r57adm
TenantDatabaseNames : {R57, TDB01, TDB02, TDB03}
TenantType  : MultiTenant
ResourceId  : schana02.gdl.englab.netapp.com\hana\MDC\R57
ResourceUid : MDC\R57
PluginName  : hana
Host: schana02.gdl.englab.netapp.com
ResourceType: MultipleContainers
Protected   : No
RunAsName   :
ResourceSettings:
MountPaths  :
DiscoveryType   : Auto
IsAuthenticated : Yes
DatabaseName: MDC
SID : MT1
UserStoreKeys   : bXQxDY8049rvqv2jPtrmFNChtY9CuhhNBSnsSJ9Fzo13LYquhwnlDknOd+QeJepEFFSIEX0AxRFcYnQVm1RR5Ky2P3oi2vgEUrPqe0UoHkfBe/QgjDeeaIrBIr4CNIiXZVwKFxOm0oLxXcf4Uluo/amAhw==
FileBackupPath  :
OSDBUser: root
TenantDatabaseNames : {}
ResourceId  : schana02.gdl.englab.netapp.com\hana\MDC\MT1
ResourceUid : MDC\MT1
PluginName  : hana
Protected   : No
RunAsName   :
ResourceSettings:
MountPaths  :
DiscoveryType   : Manual
IsAuthenticated : Not Applicable
DatabaseName : NonMDC_SN
SID  : H01
UserStoreKeys: aDAx85jqzWC0G9U7i7ohDgG1VxG7E8AxaUKyD2BeRnv+fF3sluc9aZDdPUyaWgJwQ5ZAAe0IPBY/l1PGkli2DgffnbhPjwu9fPg+nKhlErLyjXp26txx+CJJWHAniekIAsJxLdc9aUrcKO4Xm5N2wdNgdQ==
FileBackupPath   :
OSDBUser : user
ResourceId   : schana02.gdl.englab.netapp.com\hana\H01
ResourceUid  : H01
PluginName   : hana
Host : schana02.gdl.englab.netapp.com
Protected: No
RunAsName:
ResourceSettings :
MountPaths   :
DiscoveryType: Manual
Example 6: Listing all the resources of a specified resource type
 Get-SmResources -PluginCode 'hana' -HostName 'schana02.gdl.englab.netapp.com' -UseKnownResources -ResourceType 'MultipleContainers' -DatabaseName 'R57'
This example lists all the resources of a specified resource type.
Completed Discovering Resources: Job Id [47]
DatabaseName   : R57
SID: R57
UserStoreKeys  :
FileBackupPath :
OSDBUser   :
ResourceUid: MDC\R57
PluginName : hana
Protected  : No
RunAsName  :
ResourceSettings   :
MountPaths :
IsAuthenticated: No
Example 7: Trigger plug-in discovery and list the resources of specified host
 Get-SmResources -PluginCode 'hana' -HostName 'schana02.gdl.englab.netapp.com' -UseKnownResources:$false
This example syntax lists all resources of specified host.
DatabaseName: R57
SID : R57
FileBackupPath  :
OSDBUser: r57adm
PluginName  : hana
Protected   : No
RunAsName   :
ResourceSettings:
MountPaths  :
DatabaseName: MDC
SID : MT1
FileBackupPath  :
OSDBUser: root
PluginName  : hana
Protected   : No
RunAsName   :
ResourceSettings:
MountPaths  :
SID  : H01
FileBackupPath   :
OSDBUser : user
ResourceUid  : H01
PluginName   : hana
Protected: No
RunAsName:
ResourceSettings :
MountPaths   :
Example 8: Listing the resources for given sid and resource type
 Get-SmResources -HostName 'schana02.gdl.englab.netapp.com' -PluginCode hana -ResourceType MultipleContainers -UseKnownresources -SID 'R57' -DatabaseName 'R57'
This example lists all the resources of a specified host.
Completed Discovering Resources: Job Id [1692]
DatabaseName: R57
SID : R57
UserStoreKeys   : cjU3YuC1vIPicEl3zD+B6o/fev9RR0vicLMY9+9iW3DGz0WN1WiAVHFywsnSJh3vlksKbR75f2klpfhgkI27yTZPxuja5HqHsTQVrW6ZITfirN9hfM61sHeI38LSBNNaKLCsfU4kk6Okk6QzZL+RVtht1g==
FileBackupPath  :
OSDBUser: r57adm
PluginName  : hana
Protected   : No
RunAsName   :
ResourceSettings:
MountPaths  :
Example 8: Get details of the specified resource using AppObjectId
 Get-SmResources -PluginCode 'SCSQL' -HostName 'schana02.gdl.englab.netapp.com' -AppResourceId 'MVA-RX200-S13\SQLEXPRESS\DB16'
This example syntax displays the details of the resources (including cloud protection).
DBName: DB16
			DBVersion : 11.0.2100
			DBId  : MVA-RX200-S13\SQLEXPRESS\DB16
			DBType: SQL Database
			Protected : Yes
			OverallStatus :
			CloudProtected: Yes
			CloudProtectedPolices : sql_fulllog_backup_policy_daily
Example 9: Listing all Oracle Plug-in resources on a specified host
 Get-SmResources -PluginCode 'SCO' -HostName 'R8092776CF4V1.HNK2.com' -UseKnownResources
This example lists all the SnapCenter Plug-in for Oracle resources on a specified host.
DBName: DB11
			DBVersion : 19.0.0.0.0
			DBId  : R8092776CF4V1.HNK2.com\DB11
			DBType: Oracle Single Instance
			Protected : No
			OverallStatus : Not protected
			DBName: DB13
			DBId  : R8092776CF4V1.HNK2.com\DB13
			Protected : No
			Uid   : appVolLun
			Type  : Application Volume
			Protected : No
			Uid   : appVol
			Protected : No
Example 10: Listing all Oracle application volume resources on a specified host
 Get-SmResources -PluginCode 'SCO' -HostName 'R8092776CF4V1.HNK2.com' -UseKnownResources -AppObjectType 'ApplicationVolume'
This example lists all the Oracle application volume resources on a specified host.
			Uid   : appVolLun
			Protected : No
			Uid   : appVol
			Protected : No
Example 11: Listing all Oracle database resources on a specified host
 Get-SmResources -PluginCode 'SCO' -HostName 'R8092776CF4V1.HNK2.com' -UseKnownResources -AppObjectType 'Database'
This example lists all the Oracle database resources on a specified host.
			DBName: DB11
			Protected : No
			DBName: DB13
			Protected : No
Example 12: Get Oracle Plug-in resources on a specified host and filter by resource name
 Get-SmResources -PluginCode 'SCO' -HostName 'R8092776CF4V1.HNK2.com' -UseKnownResources -AppObjectType 'ApplicationVolume' -ResourceName 'appVolLun'
This example gets the SnapCenter Plug-in for Oracle resources on a specified host and filters it by resource name
			Uid   : appVolLun
			Protected : No
Example 13: Trigger Discovery of Oracle Plug-in resources on a specified host and lists them
This example triggers discovery of SnapCenter Plug-in for Oracle resources on a specified host and lists them.
			Completed Discovering Resources: Job Id [3172]
DBName: DB11
			Protected : No
			DBName: DB13
			Protected : No
			Uid   : appVolLun
			Protected : No
			Uid   : appVol
			Protected : No
