Remove-SmJobs
Removes completed jobs.
Syntax
Remove-SmJobs [-JobId] <Int32> [-StartTime] <DateTime> [-EndTime] <DateTime> [-Auth] <String>
Detailed Description
Removes completed jobs using either the job ID of a specific job or all jobs within a specified date and time.
Name | Description | Required? | Pipeline Input | Default Value |
JobId |
Specifies the ID of the job you want to remove. |
false |
false |
StartTime |
Specifies that jobs completed after the specified date and time should be removed. |
false |
false |
EndTime |
Specifies that jobs completed before the specified date and time should be removed. |
false |
false |
Auth |
false |
false |
Example 1: Removing a job using a specific job ID
Remove-SmJobs -JobId 1002
This example syntax removes the job associated with the specified job ID.
Remove-SmJobs
Are you sure want to remove all the jobs(s) ?
[Y] Yes [A] Yes to All [N] No [L] No to All [S] Suspend [?] Help (default is "Y"): y
Example 2: Removing jobs completed within specific start and end dates without a confirm dialogue
Remove-SmJobs -StartTime 02/12/2015 -EndTime 07/02/2015 -Confirm:$false
This example syntax removes jobs completed between the specified beginning and end dates.
