SnapCenter 4.9 cmdlets
Remove-SmPluginPackage
Removes a custom plug-in package from the SnapCenter repository.
Syntax
Remove-SmPluginPackage [-PluginName]  <String>  [-PluginVersion]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
PluginName
Specifies the name of the plug-in package you want to remove.
true
false
PluginVersion
Specifies the version of the plug-in you want to remove.
true
false
Example 1: Removing a custom plugin package
 Remove-SmPluginPackage -PluginName CustomPlugin -PluginVersion 1.0
This example syntax removes the 1.0 plug-in version of the custom plug-in named CustomPlugin from the SnapCenter repository.
