Restore-SmBackup
Restores a backup.
Syntax
Restore-SmBackup [-PluginCode] <PluginCode> [-AppObjectId] <String> [-BackupId] <String> [-BackupName] <String> [-LogRestoreType] <SmSqlLogRestoreType> [-RestoreWhenOnline] <> [-RetainReplicationSettings] <> [-CreateTransactionLog] <> [-FailOnTransactionLogBackupFailure] <> [-RecoveryModel] <SmSqlRecoveryModel> [-UndoLogDirectory] <String> [-Archive] <Hashtable[]> [-AuxiliaryDestination] <String> [-LogArchive] <Hashtable[]> [-AlternatePath] <Hashtable[]> [-LogCount] <Int32> [-LogCutOffDateTime] <DateTime> [-FailOnLogBackupFailure] <> [-SceRecoveryModel] <SCERecoveryModel> [-ExistingFiles] <> [-TargetHost] <String> [-NoVerify] <> [-IsRecoverMount] <> [-PreScriptCommand] <String> [-PreScriptArguments] <String> [-SQLInstanceName] <String> [-DatabaseName] <String> [-CustomLogDirectory] <String> [-RecoveryTypeHanaRecoveryType] <HanaRecoveryType> [-RecovertimezoneString] <> [-TenantDatabaseNameString] <String> [-VolumeRevertSwitchParameter] <> [-PostScriptCommand] <String> [-PostScriptArguments] <String> [-ScriptTimeOut] <Int32> [-OracleControlFileRestore] <> [-OracleFullRestore] <> [-OracleSkipRecovery] <> [-OracleUntilScn] <Int64> [-OracleTablespaces] <String> [-OracleChangeState] <> [-OraclePluggableDatabases] <String> [-AlternateArchiveLogsPath] <String> [-OracleOpenDatabaseAfterRecovery] <> [-OracleUntilTime] <DateTime> [-RestoreLastBackup] <Int32> [-RestoreOnClusterHost] <String> [-RestoreOracleRedoLogFile] <> [-OracleOpenPluggableDatabasesAfterRecovery] <> [-OracleOpenTablespacesAfterRecovery] <> [-ForceInplaceRestore] <> [-PluginCreatorCustomRestoreParams] <Hashtable> [-EnableEmail] <> [-EmailPreference] <SmEmailNotificationPreference>
Detailed Description
Restores a backup. You can specify whether to restore log files or not, and the types of log files. You can restore databases even if existing databases are online.
| Name | Description | Required? | Pipeline Input | Default Value |
PluginCode |
Specifies the plug-in code of the resource to be restored. Valid plug-in codes are SCW and SCSQL. |
true |
false |
AppObjectId |
Specifies the ID of the application object. |
true |
false |
BackupId |
Specifies the ID of the backup to use for restore. |
false |
false |
BackupName |
Specifies the name of the backup to use for restore. |
false |
false |
LogRestoreType |
Specifies the log restore type. User can choose to apply no logs, all logs or specific logs. |
false |
false |
RestoreWhenOnline |
Restore databases even if existing databases are online. |
false |
false |
RetainReplicationSettings |
Retain SQL database replication settings. |
false |
false |
CreateTransactionLog |
Create transaction log backup before restore. |
false |
false |
FailOnTransactionLogBackupFailure |
Quit restore if transaction log backup fails before restore. |
false |
false |
RecoveryModel |
Specifies the SQL recovery model for applying logs. |
false |
false |
UndoLogDirectory |
Specifies a location where the standby files are created, so that the recovery effects can be reversed. |
false |
false |
Archive |
Specifies the secondary storage system details for restore. |
false |
false |
AlternatePath |
Specifies an alternate location to restore the database. |
false |
false |
LogCount |
Specifies the number of logs to apply. |
false |
false |
AuxiliaryDestination |
Auxiliary destination on the database host required to perform Oracle point in time recovery. |
false |
false |
LogArchive |
Specify the archive location of the archive logs from where the Oracle database resource is to be restored |
false |
false |
LogCutOffDateTime |
Specifies the cutoff time to restore the database. If the server and plug-in host are in different time zones, the input must be as per the plug-in host time zone. |
false |
false |
FailOnLogBackupFailure |
false |
false |
SceRecoveryModel |
false |
false |
ExistingFiles |
Restore from Existing files specified in AlternatePath. |
false |
false |
TargetHost |
false |
false |
NoVerify |
false |
false |
IsRecoverMount |
false |
false |
PreScriptCommand |
Specifies commands that get executed before the restore operation. |
false |
true (ByPropertyName) |
PreScriptArguments |
Specifies arguments to the prescript command. |
false |
SQLInstanceName |
Specifies the SQL Server instance to which the database is restored in an alternate path scenario. |
false |
false |
DatabaseName |
Specifies the new database name when restoring the database to an alternate path. |
false |
false |
CustomLogDirectory |
This parameter is required for specifying a custom path, either a network share path or a drive path, where you have stored the logs. This parameter is used for restore operations from both primary and secondary copies. |
false |
false |
RecoveryType |
Specifies the recovery type for HANA resources. |
false |
false |
Recovertimezone |
Timezone of the client. This parameter is applicable to HANA plug-in resource when the RecoveryType specified is 'RecoverUntilDateTime'. Acceptable format: GMT+HH:MM or GMT-HH:MM. |
false |
false |
TenantDatabaseName |
Name of the HANA tenant database to be restored. This parameter is applicable to MultiTenant Database Containers resources. No recovery will be performed for the specified tenant database. |
false |
false |
VolumeRevert |
Enables file system restore in case of Complete Restore for Auto-discovered resources. This parameter is used mainly for auto-discovered resource backups and this option can be used to prevent volume based restore and cleaning up of later backups if an older backup is selected for restore. |
false |
false |
PostScriptCommand |
Specifies the commands that get executed after the restore operation. |
false |
PostScriptArguments |
Specifies the arguments to the postscript command. |
false |
ScriptTimeOut |
Specifies the maximum timeout to wait for the script to complete. |
false |
OracleControlFileRestore |
Indicates that you want to restore the Oracle control file. |
false |
false |
OracleFullRestore |
Indicates that you want to perform a full Oracle database restore. |
false |
false |
OracleSkipRecovery |
Indicates that you want to skip Oracle database recovery. |
false |
false |
OracleUntilScn |
Indicates that you want to restore to a specific System Change Number. |
false |
false |
OracleTablespaces |
Indicates the Pluggable database (PDB) tablespaces to be restored. |
false |
false |
OracleChangeState |
Indicates that the database state should be changed to the state required to perform restore and recovery operations.The states of a database from higher to lower are open, mounted, started, and shutdown. |
false |
false |
OraclePluggableDatabases |
Indicates the Pluggable databases to be restored. |
false |
false |
AlternateArchiveLogsPath |
Indicates an alternate archive logs path. |
false |
false |
OracleOpenDatabaseAfterRecovery |
Specifies that the databases must be opened after recovery is performed. |
false |
false |
OracleUntilTime |
false |
false |
RestoreLastBackup |
Restore the Nth Backup of a resource with provided AppObjectId. For example, value entered as 5 with AppObjectId "testResource", it will restore the 5th backup for resource found with AppObjectId "testResource" provided that at least 5 backups are available. |
false |
false |
RestoreOnClusterHost |
Specifies the cluster node on which the restore operation must be performed. You must specify this option only for an Oracle RAC database. If this option is not specified, restore operation is performed on the node where the backup was created. |
false |
false |
RestoreOracleRedoLogFile |
Indicates that you want to restore Oracle redo log files. Redo log file restore is only supported for Data Guard and Active Data Guard standby database. |
false |
false |
OracleOpenPluggableDatabasesAfterRecovery |
Specifies that the pluggable databases must be opened after recovery is performed. |
false |
false |
OracleOpenTablespacesAfterRecovery |
Specifies that the tablespaces must be opened after recovery is performed. |
false |
false |
ForceInplaceRestore |
Indicates that you want to perform in-place restore and bypass all restore validations. |
false |
false |
PluginCreatorCustomRestoreParams |
false |
false |
EnableEmail |
Enables e-mail. |
false |
false |
EmailPreference |
Specifies when you will receive e-mail notifications.Possible values: Always, Never, OnError, OnErrorOrWarning. |
false |
false |
EmailFrom |
Specifies the sender's e-mail address. |
true |
EmailTo |
Specifies the recipient's e-mail address. |
true |
EmailSubject |
Specifies the e-mail subject. |
true |
EnableEmailAttachment |
Enables email attachments. |
false |
Example 1: Restoring from a primary backup
PS C:\> Restore-SmBackup -PluginCode SCSQL -AppObjectId 'vise-f6\PayrollDatabase' -BackupNam
e 'NetApp_PayrollDataset_Backup Policy_vise-f6_NetApp_08-07-2015_08.48.59.6962' -RestoreWhenOnline
This example syntax restores from a primary backup.
Name: Restore 'vise-f6\PayrollDatabase'
StartTime : 8/7/2015 9:21:36 AM
EndTime :
IsCancellable : False
IsRestartable : False
IsCompleted : False
IsVisible : False
IsScheduled : False
PercentageCompleted : 0
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
Example 2: Restoring to an alternate path from a primary
e 'NetApp_PayrollDataset_Backup Policy_vise-f6_NetApp_08-07-2015_08.48.59.6962' -AlternatePath @{Source='I:\PayrollDatab
ase.mdf';Destination='H:\PayrollDatabase_copy_log.mdf'},@{Source='I:\PayrollDatabase_log.ldf';Destination='H:\PayrollDat
abase_copy_log.ldf'} -SQLInstanceName 'vise-f6\BRAVEHEART' -DatabaseName 'PayrollDatabase_copy'
This example syntax restores a backup to an alternate path
StartTime : 8/7/2015 9:30:32 AM
EndTime :
IsCompleted : False
IsVisible : False
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
Example 3: Restoring from a secondary backup
e 'NetApp_PayrollDataset_Backup Policy_vise-f6_NetApp_08-07-2015_08.48.59.6962' -Archive @{Primary="rtp-rr1-d2.gdl.engla
b.netapp.com:vol_src";Secondary="vs1:vs1_vol_src_vault"} -RestoreWhenOnline
This example syntax restores from a secondary backup.
StartTime : 8/7/2015 9:40:12 AM
EndTime :
IsCompleted : False
IsVisible : False
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
Example 4: Removing a Run As account from a resource
e 'Mycompany_PayrollDataset_Backup Policy_vise-f6_Mycompany_08-07-2015_08.48.59.6962' -Archive @{Primary="rtp-rr1-d2.gdl.mycompany.com:vol_src";Secondary="vs1:vs1_vol_src_vault"} -RestoreWhenOnline -AlternatePath @{Source='I:\PayrollDatabase.
mdf';Destination='H:\PayrollDatabase_copy_log.mdf'},@{Source='I:\PayrollDatabase_log.ldf';Destination='H:\PayrollDatabas
This example syntax removes a Run As account from a resource.
StartTime : 8/7/2015 9:46:54 AM
EndTime :
IsCompleted : False
IsVisible : False
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
Example 5: Restore complete Resource of Custom plugin DB2 from Primary Storage
Restore-SmBackup -PluginCode 'DB2' -AppObjectId 'sccorelinux61.sccore.test.com\DB2\NTP\DB1' -BackupId 191 -Confirm:$false -mountcommands 'sh /var/opt/mountCmd.sh' -unmountcommands 'sh /var/opt/unmountCmd.sh'
Restore complete Resource of type Database of Custom plug-in DB2 from Primary Storage with mount and umount commands
Example 6: Restore Complete custom plugin resource from Secondary storage
Restore-SmBackup -PluginCode 'DB2' -AppObjectId 'sccorelinux61.sccore.test.com\DB2\SECONDARYSMSV1' -BackupId 198 -Confirm:$false -customrestoreparams @{"KEY_PARAM1"="CUSTPARAM1"} -prescriptarguments 'PreScriptCommand > PreScriptCommand.txt' -prescriptcommand echo -postscriptarguments 'PostScriptCommand > PostScriptCommand.txt' -postscriptcommand echo -Archive @( @{"Primary"="vserver_scauto_primary:SMSV1_SRC_sccorelinux61_sccore_test_com";"Secondary"="vserver_scauto_primary:SMSV1_DST3_sccorelinux61_sccore_test_com"})
Restore Complete custom plug-in resource from Secondary storage with custom key-value pairs and pre-post commands
Example 7: Restore files/LUNs from Primary storage of Custom plugin resource
Restore-SmBackup -PluginCode 'DB2' -AppObjectId 'sccorelinux61.sccore.test.com\DB2\RNVOL' -BackupId 313 -Confirm:$false -path vserver_scauto_primary:/vol/ng_rvol1_sccorelinux61_sccore_test_com/file1,vserver_scauto_primary:/vol/ng_rvol2_sccorelinux61_sccore_test_com/file1
Restoring multiples files from multiple/single volumes can be combined together
Example 8: Restoring to a cluster host
Restore-SmBackup -PluginCode 'SCO' -AppObjectId 'smo-suse-11g.gdl.englab.netapp.com\itdb' -BackupName 96skdb_smo-suse-11g_02-15-2017_18.11.43.3978_0 -oraclechangestate -RestoreOnClusterHost 'clusterhost.com'
Restore to a cluster host. This is applicable only for Oracle RAC Database.
Example 9: After restore change the state of tablespaces to online
Restore-SmBackup -PluginCode 'SCO' -AppObjectId 'scspr0198204001.gdl.englab.netapp.com\itdb' -BackupName rg1_scspr0198204001_02-15-2017_16.53.38.9804_0 -oraclechangestate -OracleOpenTablespacesAfterRecovery -OracleTablespaces newts -ForceInplaceRes
After restoring the database, changes the state of the tablespaces to online
Example 10: After restore change the state of PDBS to read write
Restore-SmBackup -PluginCode 'SCO' -AppObjectId 'smo-suse-11g.gdl.englab.netapp.com\skdb' -BackupName 96skdb_smo-suse-11g_02-16-2017_17.46.09.0207_0 -oraclechangestate -OraclePluggableDatabases 'SKPDB1','SKPDB2' -OracleOpenPluggableDatabasesAfterRecovery
After restoring the database, changes the state of the PDBS to read write.
Example 11: Restoring from existing files specified in alternate path from a primary
abase_copy_log.ldf'} -SQLInstanceName 'vise-f6\BRAVEHEART' -DatabaseName 'PayrollDatabase_copy' -ExistingFiles
This example syntax restores a backup using existing files specified alternate path
EndTime :
IsCompleted : False
IsVisible : False
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
Example 12: Restore files/LUNs from Primary storage of Custom plugin resource using All File Restore option
Restore-SmBackup -PluginCode 'DummyPlugin' -AppObjectId 'scclinux1.scc.test.com\DummyPlugin\RNVOL' -BackupId 313 -Confirm:$false -AllFileRestorePath vserver_scauto_primary:/vol/ng_rvol1_scclinux1_scc_test_com
All File Restore can be performed on multiple volumes and on multiple Vservers by providing a comma separated list of volume paths from which All File Restore is to be performed
Example 13: Restore files from Primary storage of SAP HANA MultiTenant Database Container resource using All File Restore option
Restore-SmBackup -PluginCode 'hana' -AppObjectId scspr43002.scc.test.com\hana\R01\R01 -BackupId 313 -Confirm:$false -AllFileRestorePath vs_test:/vol/cn_p1,vs_test:/vol/cn_p2
Example 14: Restore files and LUNs from a Primary storage of SAP HANA MultiTenant Database Container resource
Restore-SmBackup -PluginCode 'hana' -AppObjectId scspr043002.scc.test.com\hana\R01\R01 -BackupId 3 -Confirm:$false -AllFileRestorePath vs_test:/vol/cn_p1 -Path vs_test:/vol/cn_lun_vol/cn_lun
All File Restore can be performed on multiple volumes and on multiple Vservers by providing a comma separated list of volume paths from which All File Restore is to be performed. Lun path can be provided as a value for Path parameter.
Name: Restore 'scspr043002.scc.test.com\hana\R01\R01'
StartTime : 9/28/2019 10:22:11 AM
EndTime :
IsCompleted : False
IsVisible : True
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 1
ApisJobKey :
ObjectId: 0
PluginCode : SCC
PluginName : PluginCreator
HostId : 0
RoleId :
JobIds : {}
Example 15: Restore LUNs from a specific backup of SAP HANA MultiTenant Database Containers resource
Restore-SmBackup -PluginCode 'hana' -BackupName 'schana02_gdl_englab_netapp_com_hana_MDC_R70_schana02_08-19-2019_21.07.33.2537' -AppObjectId 'schana02.gdl.englab.netapp.com\hana\MDC\R70' -RecoveryType RecoverToSpecificBackup
Restore performed to specific backup on Hana resource.
Name: Restore 'schana02.gdl.englab.netapp.com\hana\MDC\R70'
StartTime : 9/30/2019 12:40:44 PM
EndTime :
IsCompleted : False
IsVisible : True
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 1
ApisJobKey :
ObjectId: 0
PluginCode : SCC
HostId : 0
RoleId :
JobIds : {}
Example 16: Restore the HANA resource to a specific date or time (Point in time restore)
Restore-SmBackup -PluginCode 'hana' -AppObjectId 'AutoMTSles253\hana\MDC\MT1' -BackupId '469' -Confirm:$false -recovertimezone 'GMT+05:30' -recoveruntiltime '10/01/19 05:46:21 AM' -recoverytype RecoverUntilDateTime
Restore performed to a specific date or time on a HANA resource.
Name: Restore 'AutoMTSles253\hana\MDC\MT1'
StartTime : 9/30/2019 12:59:42 PM
EndTime :
IsCompleted : False
IsVisible : True
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 1
ApisJobKey :
ObjectId: 0
PluginCode : SCC
HostId : 0
RoleId :
JobIds : {}
Example 17: Restoring to a custom log directory
Restore-SmBackup -PluginCode SCSQL -AppObjectId 'RAHUL-123-123\INSTANCE2\db1' BackupName 'RAHUL-123-123_INSTANCE2_db1_SQL-123-123_06-18-2018_15.53.55.4944 -AlternatePath @{Source='F:\New folder\db1.mdf';Destination='C:\rtah\db1.mdf'},@{Source='F:\New folder\db1_log.ldf';Destination='C:\rtah\db1_log.ldf'} -SQLInstanceName 'RX200-WHQL10\INST' -DatabaseName 'DB1_RTAH' -TargetHost 'rx200-whql10.sdwdc.netapp.com' -LogRestoreType All -CustomLogDirectory "\\STAB-VM1\net share" -Archive @{Primary="RAHUL_fs1-smhv:Rahul_scsql";Secondary="RAHUL_fs.1-smhv:RAHUL_fs1_smhv_Rahul_scsql_vault"}
This example syntax specifies a custom log directory when restoring backups.
Name: : Restore 'RAHUL-123-123\INSTANCE2\db1' to instance 'RX200-WHQL10\INST'
StartTime : 6/20/2018 1:31:25 AM
EndTime :
IsVisible : True
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 1
ApisJobKey :
ObjectId: 0
PluginCode : SCSQL
PluginName : SnapCenter Plug-in for Microsoft SQL Server
HostId : 0
RoleId :
Example 18: Trigger file system restore without volume based restore
Restore-SmBackup -BackupName 'vp-hana1_gdl_englab_netapp_com_hana_MDC_N92_vp-hana1_08-20-2019_22.35.52.9698' -PluginCode hana -AppObjectId 'vp-hana1.gdl.englab.netapp.com\hana\MDC\N92'-RecoveryType SkipRecovery -VolumeRevert
This example syntax supports file system restore without volume based restore.
Name: : Restore 'vp-hana1.gdl.englab.netapp.com\hana\MDC\N92'
StartTime : 6/22/2018 1:55:10 AM
EndTime :
IsVisible : True
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 1
ApisJobKey :
ObjectId: 0
PluginCode : SCC
PluginName : hana
HostId : 0
RoleId :
Example 19: Trigger tenant database restore
Restore-SmBackup -BackupName 'vp-hana1_gdl_englab_netapp_com_hana_MDC_N92_vp-hana1_08-20-2019_22.35.52.9698' -PluginCode hana -AppObjectId 'vp-hana1.gdl.englab.netapp.com\hana\MDC\N92'-RecoveryType SkipRecovery -TenantDatabaseName N92
This example syntax restores the given tenant database.
StartTime : 6/23/2019 1:55:10 AM
EndTime :
IsVisible : True
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 1
ApisJobKey :
ObjectId: 0
PluginCode : SCC
PluginName : hana
HostId : 0
RoleId :
Example 20: Trigger HANA database restore with all logs
Restore-SmBackup -PluginCode 'HANA' -AppObjectId 'R708057AFB8V1\hana\MDC\H14' -BackupName 'R708057AFB8V1_hana_MDC_H14_R708057AFB8V1_08-25-2020_03.02.03.7780' -RecoveryType RecoverToMostRecentState -InitializeLogArea
This example syntax restores the given HANA database.
Name: Restore 'R708057AFB8V1\hana\MDC\H14'
StartTime : 8/25/2020 3:49:10 AM
EndTime :
IsCompleted : False
IsVisible : True
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
JobTypeId : 1
ApisJobKey :
ObjectId: 0
PluginCode : SCC
HostId : 0
RoleId :
JobIds : {}
Example 21: Oracle Tablespace point in time recovery (TSPITR)
Restore-SmBackup -PluginCode SCO -AppObjectId 'SLES11SP4NONE.gdl.englab.netapp.com\PITNASDB' -BackupId 65 -AuxiliaryDestination '/mnt/auxDest' -OracleTablespaces TS1 -OracleUntilScn 987450
This example syntax performs an Oracle point in time recovery for a tablespace using SCN.
Name: Restore 'SLES11SP4NONE.gdl.englab.netapp.com\PITNASDB'
StartTime : 9/11/2020 9:40:12 AM
EndTime :
IsCompleted : False
IsVisible : False
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
Example 22: Oracle Pluggable database point in time recovery
Restore-SmBackup -PluginCode SCO -AppObjectId 'SLES11SP4NONE.gdl.englab.netapp.com\PITNASDB' -BackupId 65 -AuxiliaryDestination '/mnt/auxDest' -OraclePluggableDatabases PDBUNQ -OracleUntilScn 987450
This example syntax performs an Oracle point in time recovery for a Pluggable database(PDB) using SCN.
StartTime : 9/11/2020 10:40:12 AM
EndTime :
IsCompleted : False
IsVisible : False
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
Example 23: Oracle point in time recovery for tablespace of a pluggable database (TSPITR)
Restore-SmBackup -PluginCode SCO -AppObjectId 'SLES11SP4NONE.gdl.englab.netapp.com\PITNASDB' -BackupId 65 -AuxiliaryDestination '/mnt/auxDest' -OracleTablespaces TS109 -OraclePluggableDatabases PDBUNQ --OracleUntilTime '2020-09-11 20:39:00'
This example syntax performs an Oracle point in time recovery for a tablespace belonging to a pluggable database(PDB) using time.
EndTime :
IsCompleted : False
IsVisible : False
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
Example 24: Oracle Tablespace point in time recovery (TSPITR) from secondary
Restore-SmBackup -PluginCode SCO -AppObjectId 'SLES11SP4NONE.gdl.englab.netapp.com\PITNASDB' -BackupId 65 -AuxiliaryDestination '/mnt/auxDest' -OracleTablespaces TS23 -OracleUntilScn 987450 -Archive @{Primary="svm1-scc2554-263-264:R706221F756V1_NFS_DB_DB1_DATA";Secondary="hnkn_sec:R706221F756V1_NFS_DB_DB1_DATA_dst"} -LogArchive @{Primary="svm1-scc2554-263-264:R706221F756V1_NFS_DB_DB1_LOG";Secondary="hnkn_sec:R706221F756V1_NFS_DB_DB1_LOG_mirror"}
This example syntax performs an Oracle point in time recovery for a tablespace using SCN from secondary.
StartTime : 9/11/2020 11:40:12 AM
EndTime :
IsCompleted : False
IsVisible : False
IsScheduled : False
Description :
Status : Queued
Owner :
Error :
Priority: None
Tasks : {}
ParentJobID : 0
EventId : 0
