Set-SdAluaStateMonitor
Sets the interval for monitoring ALUA path optimization.
Syntax
Set-SdAluaStateMonitor [-TimerInterval] <UInt32> [-Session] <String> [-Host] <String>
Detailed Description
Name | Description | Required? | Pipeline Input | Default Value |
TimerInterval |
Sets the time interval, in minutes, for the ALUA state monitor thread. Depending on the interval set, the system performs an optimization check for ALUA paths and repairs the paths as needed. |
true |
true (ByPropertyName) |
Session |
false |
Host |
false |
Example 1: Setting ALUA state monitor with timer interval
PS C:\> Set-SdAluaStateMonitor -TimerInterval 10
This example syntax sets the ALUA state monitor with the specified timer interval.
