Set-SmAuditSettings
Sets Audit configurations and Syslog configurations
Syntax
Set-SmAuditSettings [-MaxFileSize] <Int64> [-MaxSizeRollBackups] <Int32> [-AuditLogDirectory] <String> [-UniversalTime] <Boolean> [-AuditChecksumLogDirectory] <String> [-DiskSpaceLimitPercentage] <Int32> [-EnableAuditIntegrityCheckSchedule] <Boolean> [-EnableSyslogServer] <Boolean> [-SyslogServerHost] <String> [-SyslogServerPort] <Int32> [-SyslogProtocol] <SyslogProtocols> [-SyslogFormat] <SyslogFormats>
Detailed Description
Sets below configurations Audit related configuration - Maximum File Size Maximum files to retain Audit Log file location Audit Log Checksum file location DiskSpaceLimitPercentage Option to Enable Audit Integrity Check Schedule Syslog server related configuration - Option to Enable Syslog Server Syslog Server Host Syslog Server Port Syslog Protocol Syslog Format
Name | Description | Required? | Pipeline Input | Default Value |
MaxFileSize |
The maximum size in MB that the log file is allowed to reach before being rolled over to backup files. |
true |
false |
MaxSizeRollBackups |
The number of roll over audit files that are retained. |
true |
false |
AuditLogDirectory |
The location where audit files are generated. |
true |
false |
UniversalTime |
Enables message logging in UTC time for installations in different geographical locations. Use $True to enable UniversalTime or $False to disable UniversalTime. |
false |
false |
AuditChecksumLogDirectory |
The location where audit checksum files are generated. |
true |
false |
DiskSpaceLimitPercentage |
Disk space usage limit in percentage, after limit is reached alters are raised. |
true |
false |
EnableAuditIntegrityCheckSchedule |
To Enable scheduled audit integrity check. Possible values are $True and $False. |
true |
false |
EnableSyslogServer |
Switch to Enable forwarding audit logs to syslog server. |
true |
false |
SyslogServerHost |
Syslog server IP address or Server name. |
false |
false |
SyslogServerPort |
Syslog server Port. Possible values can range between 0 - 65535. |
false |
false |
SyslogProtocol |
Syslog server Protocol. Possible values are UDP, TCP and TLS12. |
false |
false |
SyslogFormat |
Syslog server messages format. Possible values are Rfc5424 and Rfc3164. |
false |
false |
Example 1: Setting audit log and syslog server settings
Set-SmAuditSettings -MaxFileSize 50 -MaxSizeRollBackups 10 -AuditLogDirectory 'C:\Program Files\NetApp\SnapCenter WebApp\audit' -AuditChecksumLogDirectory 'C:\Program Files\NetApp\SnapCenter WebApp\auditChecksum' -DiskSpaceLimitPercentage 80 -EnableAuditIntegrityCheckSchedule $False -EnableSyslogServer -SyslogServerHost 10.229.39.107 -SyslogServerPort 1468 -SyslogProtocol TCP -SyslogFormat Rfc5424
This example sets audit log and syslog server settings.
MaxFileSize : 50 MaxSizeRollBackups : 10 UniversalTime : False AuditLogDirectory : C:\Program Files\NetApp\SnapCenter WebApp\audit AuditChecksumLogDirectory : C:\Program Files\NetApp\SnapCenter WebApp\auditChecksum DiskSpaceLimitPercentage : 80 EnableAuditIntegrityCheckSchedule : False EnableSyslogServer : True SyslogServerHost : 10.229.39.107 SyslogServerPort : 1468 SyslogProtocol : TCP SyslogFormat : Rfc5424
