Set-SmDatasetMaintenance
Sets a dataset to maintenance or production mode.
Syntax
Set-SmDatasetMaintenance [-DatasetName] <String> [-MaintenanceStatus] <SmMaintenanceStatus>
Detailed Description
Sets a dataset to maintenance or production mode. No scheduled jobs are executed for a dataset in maintenance mode.
Name | Description | Required? | Pipeline Input | Default Value |
DatasetName |
The dataset name. |
true |
true (ByPropertyName) |
MaintenanceStatus |
The maintenance status of the dataset. The maintenance status is Production or UnderMaintenance. |
true |
Example 1: Setting a dataset to production mode
Set-SmDatasetMaintenance -DatasetName Payroll_Dataset -MaintenanceStatus Production
This example syntax set the specified dataset to production mode.
