SnapCenter cmdlets
Set-SmLogSettings
Sets the log file retention for SnapCenter, hosts, and plug-ins.
Syntax
Set-SmLogSettings [-Server]  <>  [-MaxFileSize]  <Int64>  [-MaxSizeRollBackups]  <Int32>  [-JobLogsMaxFileSize]  <Int64>  [-LogLevel]  <LogLevel>  [-UniversalTime]  <Boolean>  [-Agent]  <>  [-HostName]  <String>  [-MaxFileSize]  <Int64>  [-MaxSizeRollBackups]  <Int32>  [-JobLogsMaxFileSize]  <Int64>  [-LogLevel]  <LogLevel>  [-UniversalTime]  <Boolean>  [-Plugin]  <>  [-HostName]  <String>  [-PluginCode]  <PluginCode>  [-MaxFileSize]  <Int64>  [-MaxSizeRollBackups]  <Int32>  [-JobLogsMaxFileSize]  <Int64>  [-LogLevel]  <LogLevel>  [-UniversalTime]  <Boolean>
Detailed Description
Sets the log file retention for SnapCenter, hosts, and plug-ins. Log file settings govern log severity level, the maximum log file size, the maximum number of log file backups to retain, and the maximum size for all the job log files.
Name Description Required? Pipeline Input Default Value
Server
Indicates that you want to create log settings for the SnapCenter server.
true
false
MaxFileSize
The log file size that triggers a roll over.
true
false
MaxSizeRollBackups
The number of roll over log files that are retained.
true
false
JobLogsMaxFileSize
Specifies the maximum file size of all job log files. Job logs are created on an individual job basis. JobLogsMaxFileSize specifies the total size for all job log files. When job log files exceed the maximum size, the oldest files are deleted.
true
false
LogLevel
Sets the log severity level. Valid values are: all, debug, info, warn, error, fatal, or off.
true
false
UniversalTime
Enables message logging in UTC time for installations in different geological locations. Use $True to enable UniversalTime or $False to disable UniversalTime.
false
false
Agent
Indicates the SnapCenter agent on which you want to create the log settings. Possible values are -server, -host, or -plugin.
true
false
HostName
Specifies the host name on which the log files are created. The host should be part of the SnapCenter managed host list and the host is required when you want to create log settings for the SnapCenter host agent or plug-ins.
true
false
Plugin
Indicates that you want to specify log file settings for a plug-in host.
true
false
PluginCode
Indicates the plug-in code for the plug-in host on which you want to specify log settings. Valid plug-in values are SCSQL, SCO, SCV.
true
false
Example 1: Setting SnapCenter server log settings
 Set-SmLogSettings -JobLogsMaxFileSize 100MB -LogLevel All -MaxFileSize 10MB -MaxSizeRollBackups 10 -Server
This example syntax sets SnapCenter server log settings.
LogSettingsId  : 1
LogSettingsType: Server
LogLevel   : All
MaxFileSize: 10485760
MaxSizeRollBackups : 10
JobLogsMaxFileSize : 104857600
HostId :
HostName   :
PluginInfoId   :
PluginCode : NONE
Example 2: Setting plugin log settings
 Set-SmLogSettings –Plugin –PluginCode SMSQL -HostName host123 -JobLogsMaxFileSize 100MB -LogLevel Info -MaxFileSize 10MB -MaxSizeRollBackups 10
This example syntax sets plug-in log settings.
LogSettingsId  : 1
LogSettingsType: Plugin
LogLevel   : Info
HostId :
HostName   :
PluginInfoId   :
PluginCode : SMSQL
Example 3: Setting SnapCenter host agent log settings
 Set-SmLogSettings -Agent -HostName bryankDev -JobLogsMaxFileSize 100MB -LogLevel Info -MaxFileSize 10MB -MaxSizeRollBackups 10
LogSettingsId  : 1
LogSettingsType: Agent
LogLevel   : Info
HostId :
HostName   :
PluginInfoId   :
PluginCode : NONE
Example 4: Setting log messaging to UTC time
 Set-SmLogSettings -Agent -HostName <plugin-hostname> -JobLogsMaxFileSize 10MB -LogLevel Debug -MaxFileSize 10MB -MaxSizeRollBackups 10 -UniversalTime $True
This example syntax sets log messaging to Universal time.
