SnapCenter 4.9 cmdlets
Set-SmPolicy
Modifies an existing policy.
Syntax
Set-SmPolicy [-PolicyName]  <String>  [-PolicyType]  <SmPolicyType>  [-PluginPolicyType]  <PluginCode>  [-Description]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
PolicyName
Specifies the policy you want to change.
true
true (ByPropertyName)
PolicyType
Specifies the policy type. Valid value is Backup.
true
PluginPolicyType
Specifies the type of plug-in. You need to specify a plug-in type because policies are settings that are specific to one type of plug-in.Valid plug-in policies types are SCSQL, SCO and HANA.
true
Specifies an optional description of the policy.
false
UtmType
Type of up to the minute (UTM) retention settings to apply to log backups. Possible values are days and count.
false
UtmCount
Up to the minute (UTM) retention by count.
false
UtmDays
Up to the minute (UTM) retention by days.
false
SqlBackupType
SQL backup type. Possible values are LogBackup, FullBackup, and FullBackupAndLogBackup.
true
DatabasesPerGroup
Maximum number of databases in a group. This is applicable only for full backup.
false
CopyOnlyBackup
Determines whether the full backup is a copy only backup.
false
AGBackupType
Availability Group backup type. Possible values are UsePreferredBackupReplica and UseSpecifiedBackupReplica.
false
AGBackupReplicaType
Availability Group backup replica type. Possible values are Primary, Secondary, and All.
false
AGBackupPriorityMinimum
Availability Group backup minimum priority.
false
AGBackupPriorityMaximum
Availability Group backup maximum priority.
false
CreateLogFolderSnapshot
Create Log folder Snapshot copy.
false
EnableLogFolderSnapshotRetention
Enable Log folder Snapshot copy retention.
false
DeleteLogFolderSnapshotInExcess
Delete log folder Snapshot copies in excess of specified count. If other options are specified, then that will be ignored and only the log snapshot retention value will get modified.
false
DeleteLogFolderSnapshotOlderThan
Delete log folder Snapshot copies that are older than specified days.
false
VerifyLogBackup
Enable log backup verification after backup.
false
DBCC_NOINDEX
DBCC options NOINDEX.
false
false
DBCC_ALL_ERRORMSGS
DBCC options ALL_ERRORMSGS.
false
DBCC_NO_INFOMSGS
DBCC options NO_INFOMSGS.
false
DBCC_TABLOCK
DBCC options TABLOCK.
false
DBCC_PHYSICALONLY
DBCC options PHYSICALONLY.
false
UpdateSnapMirrorAfterbackup
Update SnapMirror copy after backup. This option is not applicable for SAP HANA policy of File-Based Backup type.
false
UpdateSnapVaultAfterbackup
Update SnapVault copy after backup. This option is not applicable for SAP HANA policy of File-Based Backup type.
false
MirrorVaultUpdateRetryCount
Number of retries to ensure SnapMirror or SnapVault update is triggered.
false
SnapVaultLabel
Label for SnapVault copy.
false
AllowSavedStateBackup
Allow saved state backup.
false
DeleteBackupInExcess
Delete backup in excess of specified days, it is applicable to only SnapCenter Plug-in for VMware vSphere, if it is used with other plug-ins it will be ignored.
false
DeleteBackupOlderThan
Delete backups older than specified days, it is applicable to only SnapCenter Plug-in for VMware vSphere, if it is used with other plug-ins it will be ignored.
false
PreScriptCommandVerification
false
PreScriptArgumentsVerification
false
PostScriptCommandVerification
false
PostScriptArgumentsVerification
false
ScriptTimeOutVerification
false
ScheduleType
The schedule type. Possible values are None, Hourly, Weekly, Daily, and Monthly.
false
RetentionSettings
Specifies in a hashtable the retention settings for the policy.
false
PreScriptCommand
Prescript file UNC path with proper privileges for scripts accessibility, (‘\\\\server\\share\path\\file’ for Universal Naming Convention (UNC) names).
false
PreScriptArguments
Specifies the prescript arguments.
false
PostScriptCommand
Postscript file UNC path with proper privileges for scripts accessibility, (‘\\\\server\\share\path\\file’ for Universal Naming Convention (UNC) names).
false
PostScriptArguments
Specifies the postscript arguments.
false
ScriptTimeOut
Specifies script timeout value in seconds.
false
VerificationScheduleType
Specifies when to run verification.
false
DeleteCloneOnScheduleExpiry
Removes a clone during the last run of a scheduled job.If this parameter is not set, then the last run of a schedule also runs a clone life cycle and creates a cloned database.This parameter does not apply to jobs that are not scheduled or to one time job schedules.
false
BackupPolicyName
Specifies the backup policy name.
true
CloneType
Specifies the clone type. Possible values are Primary and Secondary.
false
VerifyOnSecondary
Specifies whether to verify on Secondary or not.
false
false
NumOfBackups
Number of backups to be verified.
false
false
PluginParams
false
DominoChangeInfoPath
false
DominoDatabaseType
false
DominoIniPath
false
DominoRestoreFilePath
false
DominoRestoreTime
false
Lotus
false
NotesExecDirectory
false
DominoDisableReplication
false
DominoIgnoreCorruptedDB
false
DBMCliCmd
false
HandleLogWriter
false
MaxDBBGServerPrefix
false
MaxDBUpdateHistLog
false
SQLCliCmd
false
XUserEnable
false
DB2Cmd
false
SybaseISQLCmd
false
SybaseManifest
false
SybaseManifestDelete
false
SybaseManifestFormat
false
SybaseTranDump
false
SybaseTranDumpCompress
false
SybaseTranDumpFormat
false
OracleBackupType
Modifies the Oracle backup type. Type values are Online, Offline mount, and Offline shutdown.
true
OracleBackupScope
Modifies the Oracle backup scope. This parameter is only valid when the backup type is Online. Backup scope values are Full, Data, and Log.
true
OracleSkipPDBSaveState
Modifies the skip PDB save state. This parameter is only available when you select Offline shutdown backup type. Values are either True or False.
false
DeleteAllArchiveLogs
Prunes (deletes) all archive logs after Full or Log backups.
false
DeleteArchiveLogsOlderThan
Modifies the number of days before archive logs older than a specified number of days are pruned (deleted). This parameter supports the use decimals to enable you to specify a fraction of a day. For example, 2.5 represents 2 days and 12 hours, and 0.04 represents 1 hour.
false
DeleteArchiveLogFromAllDestination
Modifies whether archive logs are pruned on all destinations or only on backed up destinations. If the value is True, archive logs are pruned on all destinations. If the value is False, archive logs are pruned only on backed up destinations.
false
DeleteArchiveLogBackupInExcess
Modifies the number of archive log backups deleted in excess of the specified backup count.
false
DeleteAchiveLogBackupOlderThan
Modifies the number of archive log backups deleted that are older than the specified number of days. This parameter supports the use decimals to enable you to specify a fraction of a day. For example, 2.5 represents 2 days and 12 hours, and 0.04 represents 1 hour.
false
CatalogBackupWithOracleRMAN
false
ScwBackupType
Specifies the type of SnapCenter for Windows backup. Valid values are CrashConsistent and FilesystemConsistent.
true
SceBackupType
Specifies the backup type you want SnapCenter for Microsoft Exchange Plug-in to use.
true
UtmCounts
false
BackupTruncatedTransactionLog
false
BackupActiveCopies
false
BackupCopiesOnServer
false
BackupType
This is a SAP HANA database specific parameter. Specifies the type of SAP HANA backup. The possible values are FileBasedBackup and SnapshotBasedBackup.
true
Example 1: Modifying an existing Microsoft SQL policy
 Set-SmPolicy -PolicyName test -PluginPolicyType SCSQL -PolicyType Backup -SqlBackupType FullBackup -ScheduleType Hourly -DaysInterval 8 -StartTime $SystemTime -EndTime $SystemTimeExpire -SchedulerType SQL
This example syntax modifies an existing Microsoft SQL policy.
Example 2: Modifying an existing Oracle policy
 Set-SmPolicy -PolicyName 1 -PolicyType Backup -PluginPolicyType SCO -OracleBackupType ONLINE -OracleBackupScope FULL -DeleteAllArchiveLogs $true -DeleteArchiveLogFromAllDestination $true -DeleteArchiveLogBackupInExcess 5
Modifies an existing Oracle policy.
Example 3: Modifying an existing Windows backup policy
 Set-SmPolicy -PolicyName scw_policy3 -PolicyType Backup -PluginPolicyType SCW -ScwBackupType CrashConsistent
This example syntax modifies an existing Windows SCW policy.
Example 4: Modifying an existing SAP HANA backup policy of type SnapshotBasedBackup
 Set-SmPolicy -PolicyName hana_snapshotbased -PolicyType Backup -PluginPolicyType HANA -BackupType SnapShotBasedBackup -UpdateSnapMirrorAfterbackup $true -UpdateSnapVaultAfterbackup $true -SnapVaultLabel slabel
This example syntax modifies an existing SAP HANA backup policy of type SnapshotBasedBackup.
