SnapCenter cmdlets
Add-SmResourceGroup
Adds a resource group to SnapCenter.
Syntax
Add-SmResourceGroup [-ArchivedLocators]  <Hashtable[]>  [-ResourceGroupName]  <String>  [-BackupServers]  <SmBackupServer>  [-PluginCode]  <PluginCode>  [-EnableEmail]  <>  [-EmailPreference]  <SmEmailNotificationPreference>  [-isInternal]  <Boolean>
Detailed Description
Creates a new resource group. You can specify policies, schedules, verification schedules, and resources to be associated with the resource group.
Name Description Required? Pipeline Input Default Value
ArchivedLocators
Specifies in a hashtable the secondary storage system details for each unique primary storage system resource in the resource group. For example:-ArchivedLocators @{Primary="my_vs1:my_vol_iscsi";Secondary="my_vs1:my_vol_iscsi_SECONDARY"}
false
true (ByPropertyName)
ResourceGroupName
Specifies the name of the resource group that you want create.
true
BackupServers
false
PluginCode
Specifies the plug-in code of the host for which you are creating a backup resource group. Valid values are SCSQL, SCW, and SCO.
true
EnableEmail
Specifies whether to enable or disable email.
false
false
EmailPreference
Specifies when you will receive e-mail notifications.Possible values: Always, Never, OnError, OnErrorOrWarning.
false
false
isInternal
false
Resources
Specifies the list of resources to be associated with the resource group.You must provide the resource information in a hashtable, and it must contain the resource name and type, and the host on which it is located. For example,@{"Host"="localhost";"Type"="SQL Database";"Names"="Instance\Database"}For instance-level backup @{"Host"="localhost";"Type"="SQL Instance";"Names"="Instance"}For availability group backup @{"Host"="localhost";"Type"="SQL Availability Group";"Names"="AG1"}For custom plug-in @{"Host"="sccorelinux61.sccore.test.com";"Uid"="inst1\db1"}Valid Type values are: SQL Database, SQL Instance, SQL Availability Group.You can include comma-separated values for Names. For Oracle Database, the format is @{"Host"="host.example.com";"Oracle Database"="db1,db2,.."}. For Oracle Application Volume, the format is @{"Host"="host.example.com";"Application Volume"="appVol1,appVol2,.."}.
true
Specifies an optional description for the new resource group.
false
Tag
Enables you to apply a unique tag to help identify the resource group.
false
Policies
Specifies the list of policies associated with the resource group. Multiple policies can be added as a comma-separated list.
false
SchedulerCredentialName
false
SchedulerInstance
Specifies the SQL Server Instance where the schedule is created and managed. This is mandatory if the policy has SQL scheduler enabled.
false
VerificationServers
Specifies the list of verification servers to be associated with the resource group. Multiple verification servers can be added as a comma-separated list. This parameter is only required when you want to verify backups for SnapCenter Plug-in for Microsoft SQL Server resource groups.
false
CustomSnapshotFormat
Specifies that you want to use a custom Snapshot copy naming format. By default, a timestamp is appended to the Snapshot copy name. Valid values for CustomSnapshotFormat are : $ResourceGroup, $Policy, $HostName, $ScheduleType, $CustomText
false
CustomText
Specifies the custom text in the custom Snapshot copy naming format.
false
DeleteBackupForDetachPolicies
false
Schedules
Specifies the schedule parameters to be used in the resource group. Schedule parameters can include the policy name, schedule type, schedule start and end times. You can specify multiple schedules in a comma-separated list, for example:-Schedules @{"PolicyName"="BackupPolicy";"ScheduleType"="OneTime"}, @{"PolicyName"="BackupPolicy";"ScheduleType"="Hourly";"StartTime"=" 05/27/2016 6:13 PM";"EndTime"="05/27/2016 6:30 PM"}
false
SchedulerType
Specifies the scheduler type. Possible values are Windows, SQL, None.
false
VerificationSchedules
Specifies the verification schedules you want to add to the resource. The verification schedule includes the following parameters:"VerificationType" which defines if and when verification is performed. The following values are available:VERIFY_SCHEDULEDVERIFY_AFTER_BACKUPNONE"ScheduleType" represents the schedule type for the verification."BackupScheduleType" represents the schedule type for the backup-VerificationServers "WIN-DVGQDI73QR6" needs to be provided in the above command if we are creating verification enabled resource group for SCSQL plugin.
false
BackupArchiveLogsAfterRecentMissingOne
This option is only valid for SCO plugin code. Specifies that you want to backup archive log files, which are created after the most recent missing archive log files and ignore the files created prior to it. If this option is not specified, then all archive log files except the missing archive log files are be backed up.
false
ExcludeArchiveLogPathsFromBackup
This option is only valid for SCO plugin code. Specifies the archive log destinations to be excluded from backup. Archive log files present in the specified destinations will be excluded during log backup. Multiple entries can be specified using comma separated list. For example: -ExcludeArchiveLogPathsFromBackup '/arch/logs/on/local/disk1, /arch/logs/on/local/disk2'.
false
ConsistencyGroupSnapshot
false
ConsistencyGroupWaflSync
false
ConsistencyGroupTimeOut
false
SnapShotCreateCommand
false
UseFileSystemConsistentSnapshot
Specifies that you want to use file system consistent Snapshot copy.
false
UseSnapcenterWithoutFileSystemConsistency
false
PreAppQuiesceCmd
false
PostAppQuiesceCmd
false
AppQuiesceCmd
false
AppUnQuiesceCmd
false
PreAppUnQuiesceCmd
false
PostAppUnQuiesceCmd
false
PreExitCmd
false
PreSnapshotCmd
false
PostSnapshotCmd
false
AppIgnoreError
false
UseExternalSnapShot
false
ExternalSnapshotRegex
false
ConfigParams
false
EmailBody
Specifies the body of the email.
false
EmailFrom
Specifies the sender's email address.
true
EmailTo
Specifies the recipient's email address.
true
EmailSubject
Specifies the subject of the email.
true
EnableEmailAttachment
false
Example 1: Creating a new resource group
 Add-SmResourceGroup -ResourceGroupName DS26 -PluginCode SMSQL -Policies BackupPolicy -Resources @{"Host"="host.example.com";"Type"="SQL Database";"Names"="NB-MVA-DEV054\newdb"}
          -Description test -CustomSnapShotFomat abc -CustomText test -SchedulerRunAsName admin
          -Schedules @{"PolicyName"="BackupPolicy";"ScheduleType"="OneTime"}, @{"PolicyName"="BackupPolicy";"ScheduleType"="Hourly";"StartTime"=" 05/27/2016 6:13 PM";"EndTime"="'05/27/2016 6:30 PM'"}
          -SchedulerType Windows
This example syntax creates a new resource group.
Example 2: Adding a resource group for custom plugin with consistency group Snapshot copy enabled
 Add-SmResourceGroup -ResourceGroupName 'ResourceGroup_with_CG' -Resources @(@{"Host"="sccorelinux61.sccore.test.com";"Uid"="inst1\db1"},@{"Host"="sccorelinux61.sccore.test.com";"Uid"="inst1\db2"}) -Policies primaryonly -consistencygroupsnapshot 1 -usesnapcenterwithoutfilesystemconsistency  -plugincode 'DB2'
This example syntax creates a resource group of two DB2 databases with Consistency Group Snapshot copies enabled.
Example 3: Creating a resource group with scheduled verification
 Add-SmResourceGroup -ResourceGroupName DS26 -PluginCode SMSQL -Policies BackupPolicy -Resources @{"Host"="host.example.com";"Type"="SQL Database";"Names"="NB-MVA-DEV054\newdb"} -Description test -CustomSnapShotFomat abc -CustomText test -SchedulerRunAsName admin -Schedules @{"PolicyName"="BackupPolicy";"ScheduleType"="OneTime"}, @{"PolicyName"="BackupPolicy";"ScheduleType"="Hourly";"StartTime"=" 05/27/2016 6:13 PM";"EndTime"="'05/27/2016 6:30 PM'"} -SchedulerType Windows -VerificationSchedules @{"BackupScheduleType"="Hourly";"DeferredBackupCount"="1";"VerificationType"="VERIFY_SCHEDULED";"VerifyOnSecondary"="true";"BackupPolicyName"="BackupPolicy";"ScheduleType"="Weekly";"DaysOfTheWeek"="Monday";"StartTime"="20-Jul-16 6:42:12 PM";"EndTime"="25-Jul-16 6:42:12 PM"},@{"BackupScheduleType"="Daily";"DeferredBackupCount"="2";"VerificationType"="VERIFY_SCHEDULED";"VerifyOnSecondary"="false";"BackupPolicyName"="BackupPolicy";"ScheduleType"="Monthly";"StartTime"="20-Jul-16 6:42:12 PM";"EndTime"="25-Jul-16 6:42:12 PM";"MonthofTheYear"="March";"DaysoftheMonth"="15"} -ArchivedLocators @{Primary="test_vserver:vol_ash_test";Secondary="test_vserver:test_vserver_vol_ash_test_vault"}
This example syntax creates a new resource group with verification.
Example 4: Creating a resource group with scheduled verification and verification after backup
 Add-SmResourceGroup -ResourceGroupName RG27 -PluginCode SCO -Policies BackupPolicy -Resources @{"Host"="host.example.com";"Oracle Database"="newdb"} -Description test -CustomSnapShotFomat abc -CustomText test -SchedulerRunAsName admin -Schedules @{"PolicyName"="BackupPolicy";"ScheduleType"="Weekly";"DaysOfTheWeek"="Sunday"}, @{"PolicyName"="BackupPolicy";"ScheduleType"="Monthly";"StartTime"=" 05/27/2016 6:13 PM";"EndTime"="05/27/2016 6:30 PM";"MonthsofTheYear"="March";"DaysoftheMonth"="2"} -SchedulerType Windows -VerificationSchedules @{"BackupScheduleType"="Weekly";"DeferredBackupCount"="1";"VerificationType"="VERIFY_SCHEDULED";"VerifyOnSecondary"="true";"BackupPolicyName"="BackupPolicy";"ScheduleType"="Weekly";"DaysOfTheWeek"="Monday";"StartTime"="20-Jul-16 6:42:12 PM";"EndTime"="25-Jul-16 6:42:12 PM"},@{"BackupScheduleType"="Monthly";"DeferredBackupCount"="2";"VerificationType"="VERIFY_AFTER_BACKUP";"VerifyOnSecondary"="false";"BackupPolicyName"="BackupPolicy"}
This example syntax creates a new resource group with scheduled verification and verification after backup.
Example 5: Adding an Always On availability group
 Add-SmResourceGroup -ResourceGroupName AG_Prod -Resources @{"Host"="myag1";"Type"="SQL Availability Group";"Names"="AG_Prod"} -PluginCode SMSQL -Policies "SQL Daily Full" -Schedules @{"PolicyName"="SQL Daily Full";"ScheduleType"="Daily";"StartTime"="10/28/2017 6:13 PM";"EndTime"=""} -schedulerType SQL -SchedulerInstance SQL1
This example syntax adds an Always On availability group named AG_Prod to a SnapCenter resource group.
Example 6: Adding a resource group for HANA plugin
 Add-SmResourceGroup -ResourceGroupName '43RG57' -Resources @{"Host"="schana02.gdl.englab.netapp.com";"Uid"="MDC\R57"} -plugincode 'hana' -Policies 'HANAPOLICY'
This example adds a resource group for HANA plug-in.
Tag :
ByPassRunAs : False
Configuration   : SMCoreContracts.SmConfiguration
CreationTime: 02-Oct-19 21:38:06
CustomSnapshotFormat:
CustomText  :
Description :
EmailBody   :
EmailFrom   :
EmailNotificationPreference :
EmailSMTPServer :
EmailSubject:
EmailTo :
EnableAsupOnFailure :
EnableEmail :
EnableSysLog:
HostResourceMaping  : {}
IsCustomSnapshot:
LastBackupStatus:
MaintenanceStatus   : Production
ModificationTime: 02-Oct-19 21:38:06
PluginProtectionGroupTypes  : {hana}
Policies: {}
ProtectionGroupType : Backup
SchedulerSQLInstance:
SearchResources : False
VerificationServer  :
VerificationServerInfo  : SMCoreContracts.SmVerificationServerInfo
Type: Group
Host:
UserName:
Passphrase  :
Deleted : False
Auth: SMCoreContracts.SmAuth
IsClone : False
CloneLevel  : 0
Hosts   : {}
StorageName :
ResourceGroupNames  :
PolicyNames :
Key : 0
NsmObjectID : 0
SizeOfSmObject  :
Example 6: Creating a resource group and attaching hourly backup policy
 Add-SmResourceGroup -ResourceGroupName ResourceGroup1 -Description test -Resources @{"Host"="C226030161613-1";"Type"="SQL Database";"Names"="C226030161613-1\NAMEDINST1\C226030161613_1_SDML_1"} -Policies Full_Backup_Log_Backup_Windows_Schedule_Policy_54615264 -schedulertype 'Windows' -plugincode 'SCSQL' -schedules @{"PolicyName"="Hourly_Full_log_Backup_Wtih_Ver_Policy_09959383";"StartTime"="05/21/2019 7:54 PM";"EndTime"="05/21/2019 8:03 PM";"ScheduleType"="Hourly";"RepeatTask_Every_Hour"="03:00"}
Example 7: Creating a resource group and attaching daily backup policy
 Add-SmResourceGroup -ResourceGroupName ResourceGroup1 -Description 'Backup ResourceGroup with Full and log backup policy with Daily SQL schedule' -Resources @{"Host"="C226030161613-1";"Type"="SQL Database";"Names"="C226030161613-1\NAMEDINST1\C226030161613_1_SDML_1"} -Policies Full_Backup_Log_Backup_SQL_Schedule_Policy_54615264 -schedulerinstance 'C226030161613-1\NAMEDINST1' -plugincode 'SCSQL' -schedulerrunasname 'DomainRunAs_54615264' -schedulertype 'SQL' -schedules @{"PolicyName"="Daily_Full_Log_Backup_With_Ver_Policy_09959383";"StartTime"="05/21/2019 8:09 PM";"EndTime"="05/21/2019 9:18 PM";"ScheduleType"="Daily";"daysInterval"="1"}
Example 8: Creating a resource group and attaching weekly backup policy
 Add-SmResourceGroup -ResourceGroupName ResourceGroup1 -Description 'Backup ResourceGroup with Full and log backup policy with hourly windows schedule' -Resources @{"Host"="C226030161613-1";"Type"="SQL Database";"Names"="C226030161613-1\NAMEDINST1\C226030161613_1_SDML_1"} -Policies Full_Backup_Log_Backup_Windows_Schedule_Policy_54615264 -schedulertype 'Windows' -plugincode 'SCSQL' -schedules @{"PolicyName"="Weekly_Full_Backup_With_Ver_Policy_09959383";"StartTime"="05/21/2019 8:24 PM";"EndTime"="05/21/2019 8:41 PM";"ScheduleType"="Weekly";"DaysOfTheWeek"="Tuesday"}
Example 9: Creating a resource group and attaching monthly backup policy
 Add-SmResourceGroup -ResourceGroupName ResourceGroup1 -Description 'Backup ResourceGroup with Full and log backup policy with hourly windows schedule' -Resources @{"Host"="C226030161613-1";"Type"="SQL Database";"Names"="C226030161613-1\NAMEDINST1\C226030161613_1_SDML_1"} -Policies Full_Backup_Log_Backup_Windows_Schedule_Policy_54615264 -schedulertype 'Windows' -plugincode 'SCSQL' -schedules @{"PolicyName"="Monthly_Full_Backup_With_Ver_Policy_09959383";"StartTime"="05/21/2019 8:51 PM";"EndTime"="05/21/2019 9:18 PM";"ScheduleType"="Monthly";"MonthsOfTheYear"="May,June";"daysOfTheMonth"="21,26,16"}
Example 10: Creating a new resource group in SCE plugin
 Add-SmResourceGroup -ResourceGroupName RGName -Description test -Policies BackupPolicy -backupservers replicaServers -plugincode SCE -Resources @{"Host"="host.example.com";"Type"="SnapCenter Plug-in for Microsoft Exchange Server";"Names"="host.example.com4\newdb"}
Example 11: Creating a new resource group for Oracle Plug-in
 Add-SmResourceGroup -ResourceGroupName 'mixedRG' -Resources @(@{"Host"="R809278EA03V1.HNK2.com";"Oracle Database"="DB11,DB12"},@{"Host"="R8092776CF4V1.HNK2.com";"Application Volume"="appVol1,appVol2"}) -plugincode 'SCO' -Policies 'testPolicy'
This example syntax creates a new resource group for Oracle Plug-in containing database and application volume resources.
Example 12: Creating a new resource group for Oracle Plug-in
 Add-SmResourceGroup -ResourceGroupName 'appVolRG' -Resources @{"Host"="R8092776CF4V1.HNK2.com";"Application Volume"="appVol1,appVol2"} -plugincode 'SCO' -Policies 'testPolicy'
This example syntax creates a new resource group for Oracle Plug-in with only application volume resources.
Example 6: Adding a resource group for UnixFileSystems plugin
 Add-SmResourceGroup -ResourceGroupName 'RG_PS_linuxfs201_LVM1_12648' -Resources @{"Host"="linuxfs201.gdl.englab.netapp.com";"Type"="UnixFileSystems";Uid"="/netapp/VGNFS1/LVM1"} -plugincode 'UnixFileSystems' -Policies 'BackupPS_linuxfs201_LVM1_12648'
This example adds a resource group for UnixFileSystems plug-in.
			Tag :
			ByPassRunAs : False
			CreationTime: 12/12/2023 8:29:30 AM
			CustomText  :
			Description : Creating Resource Group
			EmailBody   :
			EmailFrom   :
			EmailSMTPServer :
			EmailSubject:
			EmailTo :
			EnableEmail :
			EnableSysLog:
			IsCustomSnapshot:
			LastBackupStatus:
			ModificationTime: 12/12/2023 8:29:30 AM
			PluginProtectionGroupTypes  : {UnixFileSystems}
			Policies: {}
			Type: Group
			Host:
			UserName:
			Passphrase  :
			Deleted : False
			IsClone : False
			CloneLevel  : 0
			Hosts   : {}
			StorageName :
			PolicyNames :
			Key : 0
			NsmObjectID : 0
			SizeOfSmObject  :
