SnapCenter 5.0 cmdlets
Add-SmUserToRole
Adds a user to a role.
Syntax
Add-SmUserToRole [-UserName]  <SmString>  [-RoleName]  <String>  [-Domain]  <String>
Detailed Description
Name Description Required? Pipeline Input Default Value
UserName
Specifies the domain\user you want to add.
true
true (ByPropertyName)
RoleName
Specifies the name of the role to which you want to add a user.
true
Domain
The domain to which the user belongs to. Workgroup users should skip this parameter.
false
Example 1: Adding a user to a role
 Add-SmUserToRole -UserName snapdrive -Domain sddev -RoleName SnapCenterAdmin
This example adds the specified user to the SnapCenter Admin role.
