SnapCenter cmdlets
Dismount-SdClone
Enables dismounting a cloned storage resource.
Syntax
Dismount-SdClone [-ClonePath]  <String[]>  [-ResourceType]  <ResourceType>  [-Session]  <String>  [-Host]  <String>
Detailed Description
Enables dismounting a cloned storage resource. This can be a single clone or a comma-separated list of clones of the same resource type.Related cmdlets: Mount-SdClone, Get-SmClone, Remove-SmClone, New-SmClone
Name Description Required? Pipeline Input Default Value
ClonePath
Specifies the path to the clone that you want to dismount. This can be a single clone or a comma-separated list of clones of the same resource type.
true
true (ByValue, ByPropertyName)
ResourceType
Specifies the type of the resource in the ClonePath parameter. The possible options are: "SDStorageVolume", "SDStorageLunPath", "SDStorageDir".
false
true (ByPropertyName)
Session
false
Host
Specifies the FQDN or IP address of the host on which you want to execute the operation.
false
Example 1: Dismount a clone from a given cloned path
 PS C:\> Dismount-SdClone -ClonePath Primary_SVM:/vol/Vol11201210041488133 -ResourceType SDStorageVolume
This example syntax specifies the cloned volume path and the resource type, and dismounts the clone.
Vserver : Primary_SVM
FullPath: Primary_SVM:/vol/Vol11201210041488133
JunctionPath:
JunctionParentName  :
SizeTotal   : 70931603456
SizeUsed: 62187937792
SnapMirrorSource:
SnapMirrorDest  :
SnapVaultPrimary:
SnapVaultSecondary  :
FlexCloneEnabled:
IsFlexClone :
VolumeSecurityStyle :
AggregateName   : Aggr4
AggregateUuid   : b3525de1-9aa0-46d2-9259-eeaef94d34b0
FlexCloneLevel  :
IsLeaf  :
VolumeState : online
AggregateAvailableSpace :
ExportPolicy: default
VolumeUuid  : fd1bb1d5-528a-11ec-a2a8-00a0986d2568
OwningVserverName   : Primary_SVM
VolumeType  :
IsProtected : False
StorageVmKey:
VolumeKey   :
VolumeInstanceUuid  :
Size:
IsRootVolume:
IsSelectable:
StorageKey  :
ProtectionStatus:
ComplianceStatus:
StatusMessage   :
SVMSloKey   :
VolumeSloKey:
SpaceGuarantee  :
PhysicalUsed: 7004160
IsFlexGroup :
ResourceType: SDStorageVolume
ResourceName: Primary_SVM:/vol/Vol11201210041488133
Ranges  :
Type:
Id  :
Host:
UserName:
Passphrase  :
Deleted : False
Auth: SMCoreContracts.SmAuth
IsClone : False
CloneLevel  : 0
Hosts   :
StorageName :
ResourceGroupNames  :
PolicyNames :
Key : 0
NsmObjectID : 0
SizeOfSmObject  :
Example 2: Dismount a set of clones from the given list of cloned paths
 PS C:\> Dismount-SdClone -ClonePath Primary_SVM:/vol/Vol11201212311309514,Primary_SVM:/vol/Vol11201212315354515 -ResourceType SDStorageVolume -Verbose
This example syntax specifies the list of cloned volume paths and their resource type, and dismounts the clones. The output is shortened for readability.
FullPath: Primary_SVM:/vol/Vol11201212311309514
FullPath: Primary_SVM:/vol/Vol11201212315354515
VERBOSE: Operation successful.
