Get-SdSnapMirror
Gets the SnapMirror relationship status for storage system volumes you specify.
Syntax
Get-SdSnapMirror [-StorageSystem] <String> [-Volume] <String[]> [-Session] <String> [-Host] <String>
Detailed Description
Gets the SnapMirror relationship status for storage system volumes you specify. If you do not specify any volumes, you retrieve SnapMirror relationships for all registered virtual storage servers.This cmdlet is supported in clustered Data ONTAP 8.2 and later. Related cmdlets: Invoke-SdSnapMirrorUpdate
Name | Description | Required? | Pipeline Input | Default Value |
StorageSystem |
Specifies the primary storage system name or IP address containing the volumes for which you want to retrieve the SnapMirror relationship status. |
false |
true (ByPropertyName) |
Volume |
Indicates a comma-separated list of storage system volumes for which you want to retrieve the SnapMirror relationship status. |
false |
Session |
false |
Host |
Specifies the name or IP address of the host on which you execute the operation. The default is your local machine. |
false |
Example 1: Getting SnapMirror information for a storage system volume
PS C:\> Get-SdSnapMirror -StorageSystem 172.17.162.61 -Volume test_vol1 -Verbose
In this example syntax, you retrieve SnapMirror relationship status information for the volume test_vol1.
Get-SdSnapMirror -StorageSystem 172.17.162.61 -Volume test_vol1 -Verbose SnapMirrorRelationshipType : data_protection SnapMirrorPolicyName : DPDefault SnapMirrorRelationship : vserver : test_vol1 ==> vserver : test_vol2 SnapMirrorState: snapmirrored SnapMirrorStatus : Idle Lag: 0 LagSpecified : False BaseSnapshotName : snapmirror.9a000021-fb71-11e1-8315-123478563412_2147484917.2013-07-19_124400 Message: Success.
Example 2: Getting SnapVault information for a storage system volume
PS C:\> Get-SdSnapMirror -StorageSystem 172.17.162.61 -Volume snapvault_source -Verbose
In this example syntax, you retrieve SnapVault relationship status information for the volume snapvault_source.
PS C:\Users\administrator.NEXTGEN> Get-SdSnapMirror -StorageSystem 172.17.162.61 -Volume snapvault_source -Verbose SnapMirrorRelationshipType : vault SnapMirrorPolicyName : XDPDefault SnapMirrorRelationship : vserver : snapvault_source ==> vserver : snapvault_dest SnapMirrorState: snapmirrored SnapMirrorStatus : Idle Lag: 0 LagSpecified : False BaseSnapshotName : DATA Message: Success.
